[mapserver-users] No transparency for layer
Henrique Rennó
henrique.renno at gmail.com
Sat Aug 25 17:43:12 PDT 2012
By the way, it's a postgis2 database. Should I change to 1.5?
2012/8/25 Henrique Rennó <henrique.renno at gmail.com>
> Searching on google, I found that other people had the same problems with
> points, but I have set symbol to "circle" and increased size with no
> success.
>> Just had another problem. It seems that point geometry from a postgis
>> database are not being displayed. What could be?
>>> Hello,
>>> I'm using a map file with "TRANSPARENT ON" and "IMAGECOLOR 255 255 255"
>>> in order to make white becomes transparent for layers and it's working. The
>>> problem is that I have one layer for roads where background is white and
>>> becomes transparent but another layer for rivers where rivers are white, so
>>> they are not displayed. Is there a way to indicate that for the rivers'
>>> layer I don't want transparency to be applied? Both geometries are loaded
>>> from a postgis database which I imported from shapefiles and the shapefiles
>>> were not made by me. The strange thing is that if I set a color for the
>>> rivers' layer within a style then the "background" is set to that color,
>>> but I thought the rivers would be colored. That means the geometry is set
>>> for everything except the rivers? That's strange.
>>> Thanks in advance
>>> Henrique
>> Henrique
> Henrique
Henrique
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120825/7b2b9355/attachment.html>
