[mapserver-users] Fwd: No transparency for layer
Henrique Rennó
henrique.renno at gmail.com
Sun Aug 26 06:54:17 PDT 2012
---------- Forwarded message ----------
Date: 2012/8/26
Subject: Re: [mapserver-users] No transparency for layer
To: pcreso at pcreso.com
Thanks for your advice, but it didn't work because I'm loading data from a
postgis geometry field and that OFFSITE option seems to be related only
when loading a raster, am I wrong?
2012/8/25 <pcreso at pcreso.com>
Try offsite for transparancy & background colours:
> http://mapserver.org/tutorial/example1-5.html
> Brent Wood
> --- On *Sun, 8/26/12, Henrique Rennó <henrique.renno at gmail.com>* wrote:
> From: Henrique Rennó <henrique.renno at gmail.com>
> To: "Mapserver-users (mapserver-users at lists.osgeo.org)" <
> mapserver-users at lists.osgeo.org>
> Date: Sunday, August 26, 2012, 12:43 PM
> By the way, it's a postgis2 database. Should I change to 1.5?
> 2012/8/25 Henrique Rennó <henrique.renno at gmail.com<http://mc/compose?to=henrique.renno@gmail.com>
> Searching on google, I found that other people had the same problems with
> points, but I have set symbol to "circle" and increased size with no
> success.
> Just had another problem. It seems that point geometry from a postgis
> database are not being displayed. What could be?
> Hello,
> I'm using a map file with "TRANSPARENT ON" and "IMAGECOLOR 255 255 255" in
> order to make white becomes transparent for layers and it's working. The
> problem is that I have one layer for roads where background is white and
> becomes transparent but another layer for rivers where rivers are white, so
> they are not displayed. Is there a way to indicate that for the rivers'
> layer I don't want transparency to be applied? Both geometries are loaded
> from a postgis database which I imported from shapefiles and the shapefiles
> were not made by me. The strange thing is that if I set a color for the
> rivers' layer within a style then the "background" is set to that color,
> but I thought the rivers would be colored. That means the geometry is set
> for everything except the rivers? That's strange.
> Thanks in advance
> Henrique
> Henrique
> Henrique
> Henrique
> -----Inline Attachment Follows-----
> mapserver-users at lists.osgeo.org<http://mc/compose?to=mapserver-users@lists.osgeo.org>
Henrique
Henrique
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120826/8ba8ba1f/attachment.html>
