[mapserver-users] still have problem when add postgis layer on mapserver mapfile
Henrique Rennó
henrique.renno at gmail.com
Sun Aug 26 09:56:00 PDT 2012
It seems your url is set wrong as mode is given twice. You have to pass
layer=layer_name
2012/8/26 李杨 <gisyangli at gmail.com>
> I try to load a postgis data layer on my mapfile, have problem when
> configure the mapfile done, then visit it using "
> http://127.0.0.1/cgi-bin/mapserv?&map=/var/www/osm-google.map&mode=map&mode=map"
> on the browser address. , only a blank blue image return, with no expected
> dot info.
> I can not figure out which step is have problem.
> Provide background info:
> ogrinfo for the database table:
> jack at jack-Vostro-1450:/usr/lib/cgi-bin$ ogrinfo PG:"host=127.0.0.1
> user=osm password=osm dbname=osm port=5432" osm_new_mainroads -summary
> INFO: Open of `PG:host=127.0.0.1 user=osm password=osm dbname=osm
> port=5432'
> using driver `PostgreSQL' successful.
> Layer name: osm_new_mainroads
> Geometry: Line String
> Feature Count: 9704
> Extent: (-9871463.421196, 3533052.471384) - (-9460289.228784,
> 4190971.740014)
> Layer SRS WKT:
> PROJCS["Popular Visualisation CRS / Mercator (deprecated)",
> GEOGCS["Popular Visualisation CRS",
> DATUM["Popular_Visualisation_Datum",
> SPHEROID["Popular Visualisation Sphere",6378137,0,
> AUTHORITY["EPSG","7059"]],
> TOWGS84[0,0,0,0,0,0,0],
> AUTHORITY["EPSG","6055"]],
> PRIMEM["Greenwich",0,
> AUTHORITY["EPSG","8901"]],
> UNIT["degree",0.01745329251994328,
> AUTHORITY["EPSG","9122"]],
> AUTHORITY["EPSG","4055"]],
> UNIT["metre",1,
> AUTHORITY["EPSG","9001"]],
> PROJECTION["Mercator_1SP"],
> PARAMETER["central_meridian",0],
> PARAMETER["scale_factor",1],
> PARAMETER["false_easting",0],
> PARAMETER["false_northing",0],
> AUTHORITY["EPSG","3785"],
> AXIS["X",EAST],
> AXIS["Y",NORTH]]
> FID Column = id
> Geometry Column = geometry
> osm_id: Integer (0.0)
> type: String (255.0)
> tunnel: Integer (5.0)
> bridge: Integer (5.0)
> oneway: Integer (5.0)
> ref: String (255.0)
> z_order: Integer (5.0)
> .map(uing in the link above : osg-google.map) info for configure:
> MAP
> NAME places1
> STATUS ON
> SIZE 800 800
> EXTENT -9871463.421196 3533052.471384 -9460289.228784 4190971.740014
> UNITS meters
> IMAGECOLOR 153 179 204
> WEB
> IMAGEPATH "/var/www/output"
> IMAGEURL "/output/"
> END
> LAYER
> STATUS DEFAULT
> NAME "places1"
> DATA "geometry from osm_new_mainroads using unique osm_id using srid 3785"
> TYPE POINT
> CONNECTIONTYPE postgis
> CONNECTION "host=localhost dbname=osm user=osm password=osm port=5432"
> CLASS
> NAME "places1_color"
> COLOR 255 215 0
> END
> END
> END
> for a explanation , whenever set "DATA "geometry from osm_new_mainroads
> using unique osm_id using srid 3785"",
> DATA "geometry from osm_new_mainroads", or
> DATA "geometry from osm_new_mainroads using unique osm_id using srid 3875
> is the same , a blank image return
> massperv version info:
> ./mapserv -v
> MapServer version 6.0.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ
> SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=GEOS
> INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> I try to experiment it in two different laptop and can not get expected
> result.
> Please those with experience help me., this problem qurrall me a lot this
> weeked.
> Thanks a lot.
> Yang Li
> GIS Developer
> P.R.China
> mapserver-users at lists.osgeo.org
Henrique
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120826/ec962999/attachment.html>
