[mapserver-users] Error compiling Mapserver 6.0.3
Lime, Steve D (DNR) Steve.Lime at state.mn.us
Mon Aug 27 11:15:16 PDT 2012
What version of flex do you have installed? --Steve
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Luís de Sousa
Sent: Monday, August 27, 2012 2:26 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Error compiling Mapserver 6.0.3
Dear all,
I'm trying to compile Mapserver 6.0.3 on Ubuntu Server 10.10 LTS, but I'm getting a compile error on maplexer.l. I reproduce below the outputs of configure and make; any insight on the issue is very welcome.
Thank you,
Luís
$ ./configure --with-ogr=/usr/local/bin/gdal-config
--with-gdal=/usr/local/bin/gdal-config --with-wfsclient --with-wmsclient --enable-debug --with-curl-config=/usr/bincurl-config --with-proj=/usr/lib/ --with-tiff --with-gd=/usr/lib/ --with-jpeg --with-freetype=/usr/include/ --with-threads --with-wcs --with-libiconv=/usr --with-geos=/usr/local/bin/geos-config --with-libiconv=/usr --with-xml2-config=/usr/bin/xml2-config --with-sos --with-postgis=/usr/lib/postgresql/9.1/bin/pg_config
checking for gcc... gcc
checking for C compiler default output file name... a.out checking whether the C compiler works... yes checking whether we are cross compiling... no checking for suffix of executables...
checking for suffix of object files... o checking whether we are using the GNU C compiler... yes checking whether gcc accepts -g... yes checking for gcc option to accept ANSI C... none needed checking for g++... g++ checking whether we are using the GNU C++ compiler... yes checking whether g++ accepts -g... yes checking for ranlib... ranlib checking for flex... no checking for lex... no checking for yywrap in -lfl... no checking for yywrap in -ll... no checking for bison... no checking for byacc... byacc checking if compiler supports -R... no checking if compiler supports -Wl,-rpath,... yes checking for exp in -lm... yes checking for __gxx_personality_v0 in -lstdc++... yes checking how to run the C preprocessor... gcc -E checking for egrep... grep -E checking for ANSI C header files... yes checking for strcasecmp... yes checking for strncasecmp... yes checking for strdup... yes checking for strrstr... no checking for strcasestr... yes checking for strlcat... no checking for strlcpy... no checking for vsnprintf... yes MapServer Version from mapserver.h: '6.0.3'
checking if pkg-config path is provided... checking for pkg-config...
/usr/bin/pkg-config
checking for Freetype2.x in /usr/include/... checking for FT_Init_FreeType in -lfreetype... yes checking for sys/types.h... yes checking for sys/stat.h... yes checking for stdlib.h... yes checking for string.h... yes checking for memory.h... yes checking for strings.h... yes checking for inttypes.h... yes checking for stdint.h... yes checking for unistd.h... yes checking ft2build.h usability... yes checking ft2build.h presence... yes checking for ft2build.h... yes
configure: checking where Zlib is installed...
checking for zlibVersion in -lz... yes
        using libz from system libs (-DUSE_ZLIB).
configure: checking where PNG is installed...
checking for png_init_io in -lpng... yes checking png.h usability... yes checking png.h presence... yes checking for png.h... yes
        using libpng from system libs.
checking setjmp.h usability... yes
checking setjmp.h presence... yes
checking for setjmp.h... yes
configure: checking where GIF is installed...
checking for DGifOpenFileHandle in -lgif... yes checking gif_lib.h usability... yes checking gif_lib.h presence... yes checking for gif_lib.h... yes
        using libgif from system libs.
configure: checking whether we should include JPEG support...
checking for jpeg_read_header in -ljpeg... yes checking jpeglib.h usability... yes checking jpeglib.h presence... yes checking for jpeglib.h... yes
        using libjpeg from system libs.
configure: checking where libXpm is installed...
checking for XpmFreeXpmImage in -lXpm... yes
        using libXpm from system libs.
configure: checking where libiconv is installed...
checking for iconv_open in -lc... yes
checking for libiconv_open in -liconv... no checking for iconv_open in -liconv... no
        using libiconv from -L/usr/lib -lc
        libiconv found. Enabling internationalization (-DUSE_ICONV)
configure: checking for GD 2.0.28 or higher...
checking for gdImageCreatePaletteFromTrueColor in -lgd... yes
        using libgd 2.0.28 (or higher) from -L/usr/lib/ -lgd -ljpeg  -lpng -lz -lXpm -lX11 checking for gdImageGif in -lc... yes checking for gdImagePng in -lc... yes checking for gdImageJpeg in -lc... yes checking for gdImageWBMP in -lc... yes checking for gdImageStringFT in -lc... yes checking for gdImageSetResolution in -lc... no checking for gdImageOpenPolygon in -lc... yes checking for gdImageGifPtr in -lc... yes checking for gdFontGetTiny in -lc... yes checking whether gdImageGetTrueColorPixel is declared... yes checking for gdImageGetTrueColorPixel in -lc... yes
        using GD ( -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DGD_HAS_FTEX_XSHOW -DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS -DGD_HAS_GET_TRUE_COLOR_PIXEL) from /usr/lib/.
checking if FTGL support requested... no checking if OGL support requested... no
configure: checking where EXPAT is installed...
checking for XML_ParserCreate in -lexpat... yes checking expat.h usability... yes checking expat.h presence... yes checking for expat.h... yes
        using libexpat from system libs.
checking for AGG support...         yes
checking if SVG Symbol support requested...         enabled
configure: checking whether we should include PROJ.4 support...
checking for pj_transform in -lproj... yes
        using PROJ.4 from /usr/lib/.
configure: checking whether we should include thread safe support...
checking for pthread_create in -lpthread... yes
        using -lpthread from system libs.
configure: checking whether we should include ESRI SDE support...
        ESRI SDE support not requested.
checking if GEOS support requested... yes user supplied geos-config (/usr/local/bin/geos-config) checking for GEOS version >= 3.0.0... yes. Found version 3.3.4
configure: checking whether we should include OGR support...
        OGR enabled (-DUSE_OGR).
checking if GDAL support requested... yes, user supplied gdal-config
(/usr/local/bin/gdal-config)
checking if PostGIS support requested... yes, user supplied pg_config
(/usr/lib/postgresql/9.1/bin/pg_config)
checking for PQconnectdb in -lpq... yes
checking for PQserverVersion in -lpq... yes checking if Mysql support requested... no checking if OracleSpatial support requested... no
configure: checking whether we should include WMS Server support...
        OGC WMS compatibility enabled (-DUSE_WMS_SVR).
configure: checking whether we should include WFS Server support...
        OGC WFS Server support not requested.
configure: checking whether we should include WCS Server support...
        OGC WCS Server support enabled (-DUSE_WCS_SVR).
configure: checking whether we should include WMS Client Connections support...
configure: checking whether we should include WFS Client Connections support...
configure: checking whether we should include OGC SOS Server support...
        OGC SOS Server support requested.
checking for curl-config... checking for curl-config... /usr/bin/curl-config
        found libcurl version 7.19.7
checking for CURLOPT_PROXYAUTH support... yes.
        OGC WMS Client Connections enabled (-DUSE_WMS_LYR).
        OGC WFS Client Connections enabled (-DUSE_WFS_LYR).
checking if KML output is requested... no checking for libxml2... yes, user supplied xml2-config
(/usr/bin/xml2-config)
        found libxml2 version 2.7.6
checking if xml-mapfile is requested... no checking if xslt is requested... no checking if exslt is requested... no checking if FriBidi support requested... no checking if Cairo support requested... no checking FastCGI support... not requested.
configure: checking HTTPD server (Apache) version...
checking for httpd... no
        'httpd' not found, skipping Apache version detection. You may want to use --with-httpd=/path/to/httpd Compiling with fast MS_NINT checking compiler warnings... basic
configure: checking whether we should enable debug features...
        Enabling debug features: -g in CFLAGS.
configure: checking whether we should enable mapserv CGI command-line debug arguments...
configure: checking for PHP/MapScript module options...
        PHP/MapScript module not configured.
checking for g++ -shared ... yes
checking if --enable-runpath requested... no checking if --with-java-include-os-name specified... no, autodetected linux
configure: creating ./config.status
config.status: creating Makefile
config.status: creating mapscript/java/Makefile
config.status: creating mapscript/csharp/Makefile
MapServer is now configured for
 -------------- Compiler Info -------------
  C compiler:                gcc -g  -fPIC -Wall
  C++ compiler:              g++ -g  -fPIC -Wall
  Debug:                     -g
  Generic NINT:
 -------------- Renderer Settings ---------
  OpenGL support:
  zlib support:              -DUSE_ZLIB
  png support:               -DUSE_PNG
  gif support:               -DUSE_GIF
  jpeg support:              -DUSE_JPEG
  freetype support:          -DUSE_FREETYPE
  iconv support:             -DUSE_ICONV
  AGG support:               internal
  SVG Symbol support:        -DUSE_AGG_SVG_SYMBOLS
  Cairo (SVG,PDF) support:
  KML support:
 -------------- Support Libraries ---------
  Proj.4 support:            -DUSE_PROJ
  Libxml2 support:           -DUSE_LIBXML2
  FriBidi support:
  Curl support:              -DUSE_CURL -DUSE_CURLOPT_PROXYAUTH
  FastCGI support:
  Threading support:         -DUSE_THREAD
  GEOS support:              -DUSE_GEOS
  XML Mapfile support:
  XSLT support:
  EXSLT support:
 -------------- Data Format Drivers -------
  PostGIS support:           -DUSE_POSTGIS -DPOSTGIS_HAS_SERVER_VERSION
  ArcSDE support:
  OGR support:               -DUSE_OGR
  GDAL support:              -DUSE_GDAL
  Oracle Spatial support:
 -------------- OGC Services --------------
  WMS Server:                -DUSE_WMS_SVR
  WMS Client:                -DUSE_WMS_LYR
  WFS Server:
  WFS Client:                -DUSE_WFS_LYR
  WCS Server:                -DUSE_WCS_SVR
  SOS Server:                -DUSE_SOS_SVR
 -------------- MapScript -----------------
  PHP MapScript:             no
$ sudo make
--  Please run "make lexer" if you have altered maplexer.l     -
gcc -c -g  -fPIC -Wall     -DHAVE_VSNPRINTF -DNEED_STRLCPY -DNEED_STRLCAT
-DNEED_STRRSTR           -DUSE_WMS_LYR -DUSE_WFS_LYR -DUSE_SOS_SVR
-DUSE_LIBXML2 -DUSE_CURL -DUSE_CURLOPT_PROXYAUTH  -DUSE_WCS_SVR
-DUSE_WMS_SVR   -DUSE_POSTGIS -DPOSTGIS_HAS_SERVER_VERSION -DUSE_GDAL
-DUSE_OGR -DUSE_GEOS  -DUSE_THREAD -DUSE_PROJ -DUSE_AGG_SVG_SYMBOLS
-DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DGD_HAS_FTEX_XSHOW -DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS -DGD_HAS_GET_TRUE_COLOR_PIXEL -DUSE_ICONV -DUSE_GIF -DUSE_PNG -DUSE_ZLIB
-DUSE_FREETYPE   -DDISABLE_CVSID -I/usr/include/ -I/usr/include//freetype2
-I/usr/lib/ -Irenderers/agg/include    -I/usr/lib/   -I/usr/local/include
-I/usr/include/postgresql    -I/usr/local/include -I/usr/include
-I/usr/include/libxml2   maplexer.c -o maplexer.o
maplexer.l: In function ‘msyylex’:
maplexer.l:178: error: ‘IN’ undeclared (first use in this function)
maplexer.l:178: error: (Each undeclared identifier is reported only once
maplexer.l:178: error: for each function it appears in.)
make: *** [maplexer.o] Error 1
View this message in context: http://osgeo-org.1560.n6.nabble.com/Error-compiling-Mapserver-6-0-3-tp4998005.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
