[mapserver-users] Error compiling Mapserver 6.0.3
Luís de Sousa
luis.a.de.sousa at gmail.com
Tue Aug 28 00:05:51 PDT 2012
Hi Cristiano, after removing byacc I get this in the configuration:
checking for flex... flex
checking for yywrap in -lfl... yes
checking lex output file root... lex.yy
checking whether yytext is a pointer... yes
checking for bison... no
checking for byacc... no
Then running make I get the exact same error as before. Thank you,
Luís
On 27 August 2012 19:01, Cristiano Sumariva <sumariva at gmail.com> wrote:
> Your configure reports a byacc. Try remove it and run again.
> checking for byacc... byacc
> This is an output for 5.6.7 mapserver that compiled on my older Ubuntu
> system.
> checking for flex... no
> checking for lex... no
> checking for yywrap in -lfl... no
> checking for yywrap in -ll... no
> Hope it helps some.
