[mapserver-users] Error compiling Mapserver 6.0.3
thomas bonfort
thomas.bonfort at gmail.com
Tue Aug 28 00:36:35 PDT 2012
Luis,
Our repo contains a generated version of maplexer.c that should not
need to be re-generated by end users. You should be able to either
uninstall flex and/or copy back the original version of maplexer.c to
get going.
thomas
On Tue, Aug 28, 2012 at 9:05 AM, Luís de Sousa
<luis.a.de.sousa at gmail.com> wrote:
> Hi Cristiano, after removing byacc I get this in the configuration:
> checking for flex... flex
> checking for yywrap in -lfl... yes
> checking lex output file root... lex.yy
> checking whether yytext is a pointer... yes
> checking for bison... no
> checking for byacc... no
> Then running make I get the exact same error as before. Thank you,
> Luís
> On 27 August 2012 19:01, Cristiano Sumariva <sumariva at gmail.com> wrote:
>> Your configure reports a byacc. Try remove it and run again.
>> checking for byacc... byacc
>> This is an output for 5.6.7 mapserver that compiled on my older Ubuntu
>> system.
>> checking for flex... no
>> checking for lex... no
>> checking for yywrap in -lfl... no
>> checking for yywrap in -ll... no
>> Hope it helps some.
> mapserver-users at lists.osgeo.org
