[mapserver-users] OGR Virtual Format and character encoding
Frank Warmerdam
warmerdam at pobox.com
Fri Aug 31 13:16:50 PDT 2012
Chris,
I'm a bit unclear if the problem is happening in the MS SQL driver, or in the
VRT driver. If you use OGR directly against the MS SQL data are things
messed up? Are you using ODBC or the actual MSSQLSpatial driver?
Best regards,
Frank
On Fri, Aug 31, 2012 at 1:07 PM, Chris Jackson <webturtles at gmail.com> wrote:
> All
> One thought I did have, if the characters where html encoded in the SQL
> table (e.g. ü as ü) is there anyway to get MapServer to render them
> correctly again in a label? I guess OGR can only deal with UTF-8 encoded
> characters (I am using nvarchar fields, but in an ISO collation in SQL 2005
> - not v.UTF-8 friendly I think!)
> Thanks
> Chris
> On 30 August 2012 15:46, Chris Jackson <webturtles at gmail.com> wrote:
>> Hi all
>> I have OGR Virtual Format layer in my map file and the underlying .OVF is
>> calling a flat MS SQL table of point data. The layer displays fine, but I
>> am having issues with umlauts etc for one of the attribute fields. When I
>> run the ogrinfo command on the layer, it has already messed up the encoding.
>> In SQL it looks and queries fine. Any pointers on how you can maintain the
>> encoding?
>> Many thanks
>> Chris
> mapserver-users at lists.osgeo.org
and watch the world go round - Rush | Geospatial Software Developer
