[mapserver-users] Compiling Mapserver (6.2) with PostGIS support Without PG on the machine
Martin Ouellet
geomartino at gmail.com
Thu Dec 20 13:14:37 PST 2012
*Compiling *
*GDAL **--with-pg=/usr/pgsql-9.2/bin/pg_config*
*and*
*Mapserver **--with-postgis=/usr/pgsql-9.2/bin/pg_config *
*solved my problem!*
*cheers*
*MartinO*
On Thu, Dec 20, 2012 at 10:08 AM, Martin Ouellet <geomartino at gmail.com>wrote:
> Hi,
> I want to compile Mapserver (6.2) on a RHEL5 64bit machine with PostGIS
> support but Postgresql is NOT installed on the machine.
> Before I run the compilation, I've have installed some libraries (with yum
> rpm):
> postgresql92.x86_64
> postgresql92-libs.x86_64
> postgresql92-devel.x86_64
> I think the required libraries for the PostGIS support are
> there because find / -name 'libpq*'
> return
> /usr/pgsql-9.2/lib/libpq.so.5
> /usr/pgsql-9.2/lib/libpq.a
> /usr/pgsql-9.2/lib/libpq.so.5.5
> and more....
> When I execute
> * ./configure --prefix=/usr/local/ --with-gdal=/usr/local/bin/gdal-config
> --with-ogr=/usr/local/bin/gdal-config
> --with-curl=/usr/bin/curl-config[[BR]] --enable-debug
> --with-proj=/usr/local/ --with-tiff=/usr/ --with-jpeg=/usr/local/
> --with-freetype=/usr/local/ --with-threads
> --with-xml2-config=/usr/bin/xml2-config --with-png=/usr/ --with-wmsclient
> --with-wmsserver --with-wfs --with-wfsclient --with-gif=/usr/
> --with-geos=/usr/local/bin/geos-config --with-postgis*
> *I've got*
> -------------- Data Format Drivers -------
> PostGIS support:
> ArcSDE support:
> OGR support: -DUSE_OGR
> GDAL support: -DUSE_GDAL
> Oracle Spatial support:
> any idea?
> MartinOuellet
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20121220/2c77dd72/attachment.html>
