[mapserver-users] Pie chart does not show
thomas bonfort
thomas.bonfort at gmail.com
Tue Jul 3 06:10:05 PDT 2012
Not sure what your're trying to obtain, or how to write mssql queries,
but charts work when your data query returns rows that are of the
form:
[geometry,attribute1,attribute2,attribute3,...]
each pie slice is defined with a mapserver CLASS:
CLASS
NAME "attribute1"
STYLE
SIZE [attribute1]
COLOR r1 g1 b1
END
END
CLASS
NAME "attribute2"
STYLE
SIZE [attribute2]
COLOR r2 g2 b2
END
END
thomas
On Tue, Jul 3, 2012 at 12:59 AM, julia paredes <japr94 at hotmail.com> wrote:
> Hi all
> I want to create a pie chart for some data. The problem that I'm facing is
> that i'm not getting any errors when I test the layer using shp2img;
> however, I just get a white image. This is my mapfile:
> MAP
> EXTENT -20037508 -20037508 20037508 20037508
> SIZE 400 400
> IMAGETYPE PNG
> LAYER
> NAME "Survey"
> TYPE CHART
> CONNECTIONTYPE OGR
> CONNECTION "MSSQL:server=myserver;database=data;uid=me;pwd=key"
> DATA "SELECT Option, COUNT(*) AS RESULT FROM Survey GROUP BY Option"
> PROCESSING "CHART_TYPE=pie"
> PROCESSING "CHART_SIZE=30"
> STATUS ON
> CLASSITEM 'Option'
> CLASS
> EXPRESSION '1'
> NAME "one"
> STYLE
> SIZE [RESULT]
> COLOR 255 244 237
> END
> END
> CLASS
> EXPRESSION '2'
> NAME "two"
> STYLE
> SIZE [RESULT]
> COLOR 255 217 191
> END
> END
> CLASS
> EXPRESSION '3'
> NAME "three"
> STYLE
> SIZE [RESULT]
> COLOR 255 186 140
> END
> END
> CLASS
> EXPRESSION '4'
> NAME "Four"
> STYLE
> SIZE [RESULT]
> COLOR 255 186 0
> END
> END
> END
> END
> Any ideas of what could be missing in my mapfile?
> Thanks
> mapserver-users at lists.osgeo.org
