[mapserver-users] msLoadMSRasterBufferFromFile(): General error message. unable to open file
thomas bonfort
thomas.bonfort at gmail.com
Tue Jul 3 06:13:50 PDT 2012
You're getting this error because the "7383" symbol was not found in
the symbolset.
I would first check you are actually loading the symbolset that
contains the definition for 7383, or even inline the 7383 symbol in
your mapfile. If that still fails, try renaming your symbol to
something that begins with non numeric characters. If the last action
solves your problem, please open a issue as this would be a bug.
regards,
thomas
On Fri, Jun 29, 2012 at 6:15 PM, xam <torrespri at gmail.com> wrote:
> Hello, I recently updated to version 6.0.2 mapserver.
> I have a mapfile that uses a file of symbols, which use a truetype font that
> I have defined it.
> In version 5.6 worked perfectly, but now I have this message: /msDrawMap ():
> Image handling error. Failed to draw layer named 'airport'.
> msLoadMSRasterBufferFromFile (): General error message. unable to open file
> /var/www/ms/7383 for reading./
> The airport layer definition is:
> CLASS
> NAME 'Airport'
> STYLE
> SYMBOL "7383"
> SIZE 16
> COLOR 110 110 110
> OUTLINECOLOR 255 0 0
> END
> LABEL
> FONT sans
> TYPE truetype
> SIZE 8
> COLOR 0 0 0
> ANGLE 0
> POSITION uc
> FORCE true
> AntiAlias true
> # PARTIALS true
> # BackgroundColor 255 255 255
> OUTLINEWIDTH 5
> OUTLINECOLOR 255 255 255
> BUFFER 10
> END
> END
> and the symbol 7383:
> SYMBOL # Airport
> NAME "7383"
> TYPE TRUETYPE
> FONT "poi"
> CHARACTER "B"
> TRUE AntiAlias
> END
> The source truetype "poi" I have created myself and I have included in the
> file fonts.
> I thought it could be for OUTPUTFORMAT, I use
> DRIVER AGG / PNG
> IMAGEMODE RGBA, but don't know.
> Might miss some library?
> Thanks for your help
> Pepe
> View this message in context: http://osgeo-org.1560.n6.nabble.com/msLoadMSRasterBufferFromFile-General-error-message-unable-to-open-file-tp4984932.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
