[mapserver-users] Remote map server - data tweaking
Ruslan Nuryadin
nuryadin at gmail.com
Thu Jul 5 21:51:59 PDT 2012
When using Quantum GIS, I usually use SQL query where clause to filter
PostGIS dataset:
- at Add PostGIS Table(s) dialog, click Build query button
- fill in SQL where clause with any filter condition
- for bounding box filter, use intersection clause like
intersects(the_geom, 'SRID=4326;POLYGON((106 -7,107 -7,107 -6,106 -6,106 -7))')
this will filter dataset that closely match (106, -7) to (107, -6) bounding box
On Fri, Jul 6, 2012 at 11:17 AM, Rahkonen Jukka
<Jukka.Rahkonen at mmmtike.fi> wrote:
> Hi,
> Check this TinyOWS example http://mapserver.org/trunk/tinyows/openlayershowtotransactional.html
> However, from what I know Qgis does not load all the features but only those which intersect the map window. "Open attribute table" seems to read the attributes from the whole table but for editing attributes of a single feature you can point it with the info tool and then open the "Edit feature form" with right click.
> QGis is also a WFS-T client and it can be used for editing data through TinyOWS. The current QGis development version seems to miss the bounding box filter option so it is now downloading the whole table through WSF. Therefore it is unusable with big WFS layers at the moment. Let's hope they will re-activate the BBOX check box soon.
> -Jukka Rahkonen-
> ________________________________
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org] käyttäjän Matt McClelland [matt at wildwalks.com] puolesta
> Lähetetty: 6. heinäkuuta 2012 4:30
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Aihe: [mapserver-users] Remote map server - data tweaking
> Hi All
> I am looking for a simple editing tool that will allow me to edit vector map data on my remote mapserver DB (postgres)
> Ideally something like Potlatch 2 (From ww.osm.org<http://ww.osm.org>)
> I want to be able to download a small area of data, move a few notes on a line a bit (or delete it the line), and commit those changes to the DB.
> I have used quantum GIS - It is good, but it seems to download all the data from the table, not just what is in view.
> Not really a mapserver question, but somewhat related.
> Any ideas welcome - thanks
> Matt :)
Ruslan Nuryadin
