[mapserver-users] php-mapscript problem and symbolname trying to open a file?
Ben Madin
lists at remoteinformation.com.au
Fri Jul 6 01:33:58 PDT 2012
G'day all,
I'm not sure if this is two problems, or the second problem is a result of the first. The second problem is that I have a mapfile with multiple sections that look like :
CLASS
NAME "Sentinel Positive"
EXPRESSION "SentPos"
STYLE
ANGLE 0
COLOR 220 20 40
OFFSET 0 0
SIZE 8
SYMBOL "circle"
END # STYLE
END # CLASS
where symbol is :
SYMBOL # 1
NAME 'circle'
TYPE ELLIPSE
POINTS 1 1 END
FILLED TRUE
END
and when I try to open it, I get :
msDrawMap(): Image handling error. Failed to draw layer named 'BLU'. <br>
msLoadMSRasterBufferFromFile(): General error message. unable to open file /usr/local/www/apache22/data/system/mapserver/maps/tmpmapfiles/./circle for reading <br>
I know that SYMBOL can be a name (in the symbol file) or a filename, but clearly it is getting confused.
The first problem is that this file is one of several that is meant to be generated by a looping structure in php-mapscript, and I am getting :
[Fri Jul 06 18:08:13 2012] [notice] child pid 74615 exit signal Abort trap (6)
Assertion failed: (pixmap->type == MS_BUFFER_BYTE_RGBA), function agg2RenderPixmapSymbol, file mapagg.cpp, line 464.
[Fri Jul 06 18:08:57 2012] [notice] child pid 74300 exit signal Abort trap (6)
errors when I try to build the layers (this is the only one that builds). I'm a little short on ideas as to where to go next.
this is :
MapServer version 6.0.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=GEOS INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
Server version: Apache/2.2.22 (FreeBSD)
PHP 5.4.4 (cli) (built: Jun 20 2012 07:13:50)
FreeBSD FreeBSD 8.2-RELEASE-p4 amd64
cheers
Ben
