[mapserver-users] PHP mapscript using OracleSpatial
Eichner, Andreas - SID-NLKM
Andreas.Eichner at sid.sachsen.de
Fri Jul 6 00:56:15 PDT 2012
Hello Jessica,
I've tested your code successfully on PHP MapScript v5.2.0.
> I have issues with
> oraclespatial, and I just keep getting errors that the layer
> can't be drawn.
What errors do you get? Something like "[...] Error: ORA-12154:
TNS:could not resolve the connect identifier specified"? Then you
might need to set some environment variables first. For example,
I set ORACLE_HOME, TNS_ADMIN, LC_CTYPE and NLS_LANG.
> The lack of error reporting from
> php hasn't been helping matters either ;)
You can execute your script on the command line via "php <scriptname>".
This will display errors as long as error_reporting(E_ALL) or similar
is set:
$ php test.php
Warning: [MapServer Error]: msDrawMap(): Failed to draw layer named
'ASSET'.
in /tmp/foo/test.php on line 53
Warning: [MapServer Error]: msOracleSpatialLayerOpen(): Cannot create
OCI Handlers. Connection failure. Check the connection string. Error:
ORA-12154: TNS:could not resolve the connect identifier specified
Error in msDrawMap(): Failed to draw layer named 'ASSET'.<br>
HTH
