[mapserver-users] Template Questions (was How to get layer name in an identify template?)
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Fri Jul 6 08:29:40 PDT 2012
That's not to say the references are completely current. ;-)
If you do run a across missing information or whatever it's easiest to just file a ticket, or drop a note to the mailing list.
To answer your other questions:
* [bbox] is not a standard template tag. However, if you set a variable called "bbox" in your query request then that variable is available in template output (HTML escaped first to prevent cross-site scripting).
* [shpext] and other feature specific tags can only be used within a [feature] block or in the old-style feature templates. Perhaps this can be made clearer in the docs.
Steve
From: Donald Kerr [mailto:donald.kerr at dkerr.co.uk]
Sent: Friday, July 06, 2012 10:19 AM
To: Lime, Steve D (DNR); 'Bistrais, Bob'; mapserver-users at lists.osgeo.org
Subject: RE: [mapserver-users] How to get layer name in an identify template?
Thank you for the references, Steve.
I'm sure I've used "[bbox]" in a template which is not listed in the first link. I think I also had some issues regarding where tags like "[shpext]" can be used within or outwith the "[resultset layer=LayerName]" and "[feature]" tags. I will need to revisit the work that I was doing since I've put it on the back burner just now. I don't want to hi-jack this thread which is now resolved.
Regards,
Donald
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120706/c7ff2097/attachment.html>
