[mapserver-users] One template for every text type
Eichner, Andreas - SID-NLKM
Andreas.Eichner at sid.sachsen.de
Wed Jul 11 04:20:28 PDT 2012
The URL actually gives a feature result (#135), but no attribute data.
You need to set {wms,ows}_include_items metadata at layer level:
* wms/ows_include_items: comma delimited list or keyword 'all'
HTH
> -----Ursprüngliche Nachricht-----
> Von: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Im Auftrag
> von Andrea Peri
> Gesendet: Mittwoch, 11. Juli 2012 12:45
> An: Lime, Steve D (DNR)
> Cc: mapserver-users at lists.osgeo.org
> Betreff: Re: [mapserver-users] One template for every text type
> Hi Steve,
> thx very much for you rhint.
> I ubnderstand and start to try it.
> Now I found some strange.
> It seem mapserver trunk don't work well when mime/type = text/plain.
> I see infact the sample link in the documentation for text/plain
> repeort this result
> (no feature listed)
> http://demo.mapserver.org/cgi-bin/wms?SERVICE=WMS&VERSION=1.1.
> 1&REQUEST=GetFeatureInfo&BBOX=-11.332970,24.121208,47.584718,5
> 7.965035&SRS=EPSG:4326&WIDTH=1001&HEIGHT=575&LAYERS=cities&STY
LES=&FORMAT=image/png&TRANSPARENT=true&QUERY_LAYERS=cities&INFO_FORMAT=text/plain&X=229&Y=280
> Instead using the html link mapserver list the features.
LES=&FORMAT=image/png&TRANSPARENT=true&QUERY_LAYERS=cities&INFO_FORMAT=text/html&X=229&Y=280
> 2012/7/9 Lime, Steve D (DNR) <Steve.Lime at state.mn.us>
> The QUERYABLE parameter was never implemented so you
> still must define a layer TEMPLATE to mark a layer as being
> queryable. The template need not exist so typically I just do:
> TEMPLATE 'void'
> The link between layers and OUTPUTFORMAT templates are
> in the templates themselves via the [resultset] tag.
> Steve
> From: Andrea Peri [mailto:aperi2007 at gmail.com]
> Sent: Monday, July 09, 2012 5:15 AM
> To: Lime, Steve D (DNR)
> Subject: Re: [mapserver-users] One template for every text type
> Hi Steve,
> thx for hint.
> I read the doc and also the RFC 36.
> I'm having also some doubt.
> I try to set this output format:
> OUTPUTFORMAT
> NAME "delimitazione_fogli_xml"
> MIMETYPE "text/xml"
> DRIVER "TEMPLATE"
> FORMATOPTION
> "FILE=/pat-to-ex-template-on-layer-level/template_xml.tmpl"
> END
> at WEB level I set this value:
> WEB
> METADATA
> "wms_feature_info_mime_type" "text/xml"
> END
> END
> And how explained from RFC I comment the template from
> layer level and try to add the tag
> QUERYABLE TRUE
> (But this option seem to be not supported from
> MapServer 6.2 trunk)
> If I remove the template tag from layer level I have this error:
> msWMSFeatureInfo(): WMS server error. Requested
> layer(s) are not queryable.
> And if I try to add the QUERYABLE TRUE tag I have
> this error:
> >Unknown identifier. Parsing error near (QUERYABLE)
> So I need to maintain the template ad Layer level. This
> force the layer to use the template from that tag instead of
> the tag from FORMATOPTION.
> Also I don't understand how to link the specific format
> option the a specific layer.
> Thx,
> Andrea.
> 2012/7/6 Lime, Steve D (DNR) <Steve.Lime at state.mn.us>
> Hi Andrea: You can define multiple output formats that
> use the template driver. They can each have different names
> and mime-types. You can even use mime subtypes if you needed,
> say, two XML formats. The MapServer CGI supports a parameter
> called qformat that allows you to change the query template
> to be used. I'm not sure how this works with WFS, probably
> via mime-type.
> Steve
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of
> Andrea Peri
> Sent: Tuesday, July 03, 2012 5:42 PM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] One template for every text type
> Hi,
> As report from documentation, MapServer will allow to
> define a template to set the return from an identify.
> I need to define almost two distinct kind of returns:
> One for user (text/plain or text/html) and one for
> business application (text/xml).
> So I like to define not only a template for return an
> XML but also a template for return an html page.
> I don't know how to say to MapServer what template us
> for text/html and what for text/xml.
> Is this possibile ?
> Thx.
> Andrea Peri
> qwerty àèìòù
> Andrea Peri
> qwerty àèìòù
> Andrea Peri
> qwerty àèìòù
