[mapserver-users] One template for every text type
Andrea Peri
aperi2007 at gmail.com
Wed Jul 11 05:38:55 PDT 2012
thx very much.
your suggestion is reallly useful.
this setting,
ows_include_items "all"
seem to be not available on documentation.
the documentation report only the
"gml_include_items" but it don't work for text/plain.
I you setting and all the attributes are appeared.
Also I'm see-ing the outputformat (a template driven I have setting) is
ignored.
I don't know if this is correct.
Actually seem MapSever
will generate the output of a GetFeatureInfo using template driven only if
not set the
Andrea.
2012/7/11 Eichner, Andreas - SID-NLKM <Andreas.Eichner at sid.sachsen.de>
> The URL actually gives a feature result (#135), but no attribute data.
> You need to set {wms,ows}_include_items metadata at layer level:
> * wms/ows_include_items: comma delimited list or keyword 'all'
> HTH
> > -----Ursprüngliche Nachricht-----
> > Von: mapserver-users-bounces at lists.osgeo.org
> > [mailto:mapserver-users-bounces at lists.osgeo.org] Im Auftrag
> > von Andrea Peri
> > Gesendet: Mittwoch, 11. Juli 2012 12:45
> > An: Lime, Steve D (DNR)
> > Cc: mapserver-users at lists.osgeo.org
> > Betreff: Re: [mapserver-users] One template for every text type
> > Hi Steve,
> > thx very much for you rhint.
> > I ubnderstand and start to try it.
> > Now I found some strange.
> > It seem mapserver trunk don't work well when mime/type = text/plain.
> > I see infact the sample link in the documentation for text/plain
> > repeort this result
> > (no feature listed)
> > http://demo.mapserver.org/cgi-bin/wms?SERVICE=WMS&VERSION=1.1.
> > 1&REQUEST=GetFeatureInfo&BBOX=-11.332970,24.121208,47.584718,5
> > 7.965035&SRS=EPSG:4326&WIDTH=1001&HEIGHT=575&LAYERS=cities&STY
> LES=&FORMAT=image/png&TRANSPARENT=true&QUERY_LAYERS=cities&INFO_FORMAT=text/plain&X=229&Y=280
> > Instead using the html link mapserver list the features.
> LES=&FORMAT=image/png&TRANSPARENT=true&QUERY_LAYERS=cities&INFO_FORMAT=text/html&X=229&Y=280
> > 2012/7/9 Lime, Steve D (DNR) <Steve.Lime at state.mn.us>
> > The QUERYABLE parameter was never implemented so you
> > still must define a layer TEMPLATE to mark a layer as being
> > queryable. The template need not exist so typically I just do:
> > TEMPLATE 'void'
> > The link between layers and OUTPUTFORMAT templates are
> > in the templates themselves via the [resultset] tag.
> > Steve
> > From: Andrea Peri [mailto:aperi2007 at gmail.com]
> > Sent: Monday, July 09, 2012 5:15 AM
> > To: Lime, Steve D (DNR)
> > Subject: Re: [mapserver-users] One template for every text type
> > Hi Steve,
> > thx for hint.
> > I read the doc and also the RFC 36.
> > I'm having also some doubt.
> > I try to set this output format:
> > OUTPUTFORMAT
> > NAME "delimitazione_fogli_xml"
> > MIMETYPE "text/xml"
> > DRIVER "TEMPLATE"
> > FORMATOPTION
> > "FILE=/pat-to-ex-template-on-layer-level/template_xml.tmpl"
> > END
> > at WEB level I set this value:
> > WEB
> > METADATA
> > "wms_feature_info_mime_type" "text/xml"
> > END
> > END
> > And how explained from RFC I comment the template from
> > layer level and try to add the tag
> > QUERYABLE TRUE
> > (But this option seem to be not supported from
> > MapServer 6.2 trunk)
> > If I remove the template tag from layer level I have this error:
> > msWMSFeatureInfo(): WMS server error. Requested
> > layer(s) are not queryable.
> > And if I try to add the QUERYABLE TRUE tag I have
> > this error:
> > >Unknown identifier. Parsing error near (QUERYABLE)
> > So I need to maintain the template ad Layer level. This
> > force the layer to use the template from that tag instead of
> > the tag from FORMATOPTION.
> > Also I don't understand how to link the specific format
> > option the a specific layer.
> > Thx,
> > Andrea.
> > 2012/7/6 Lime, Steve D (DNR) <Steve.Lime at state.mn.us>
> > Hi Andrea: You can define multiple output formats that
> > use the template driver. They can each have different names
> > and mime-types. You can even use mime subtypes if you needed,
> > say, two XML formats. The MapServer CGI supports a parameter
> > called qformat that allows you to change the query template
> > to be used. I'm not sure how this works with WFS, probably
> > via mime-type.
> > Steve
> > From: mapserver-users-bounces at lists.osgeo.org
> > [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of
> > Andrea Peri
> > Sent: Tuesday, July 03, 2012 5:42 PM
> > To: mapserver-users at lists.osgeo.org
> > Subject: [mapserver-users] One template for every text type
> > Hi,
> > As report from documentation, MapServer will allow to
> > define a template to set the return from an identify.
> > I need to define almost two distinct kind of returns:
> > One for user (text/plain or text/html) and one for
> > business application (text/xml).
> > So I like to define not only a template for return an
> > XML but also a template for return an html page.
> > I don't know how to say to MapServer what template us
> > for text/html and what for text/xml.
> > Is this possibile ?
> > Thx.
> > Andrea Peri
> > qwerty àèìòù
> > Andrea Peri
> > qwerty àèìòù
> > Andrea Peri
> > qwerty àèìòù
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120711/f04c1261/attachment-0001.html>
