[mapserver-users] GetCoverage with WCS 2.0.0: Unknown parameter time
Stephan Meißl
stephan at meissl.name
Tue Jul 17 09:56:18 PDT 2012
Hi Jonas,
which version of MapServer are you using? I guess variable substitution
should also be available in WCS 2.0. Could you send a short Mapfile and
request to reproduce the behavior?
cu
Stephan
On Tue, 2012-07-17 at 11:51 -0500, Jonas Eberle wrote:
> Hi list,
> I tried to use WCS 2.0.0 with Mapserver. Having time series layers
> with a tile index layer, I used variable substitution for the
> different times. This works fine for WCS 1.0.0.
> Trying the GetCoverage request with WCS 2.0.0 I get the following
> error message right after executing the request:
> msWCSParseRequest20(): WCS server error. Unknown parameter: 'time'.
> Is there an other possibility to use variable substitution with
> GetCoverage request in WCS 2.0.0?
> Thanks,
> Jonas
> mapserver-users at lists.osgeo.org
