[mapserver-users] ArcInfo Grid with MapServer
jorgelopez
jorgelopez.physics at gmail.com
Mon Jul 23 08:04:49 PDT 2012
Hello everyone:
I have some problems trying to render Arc Info Grids with MapServer. I am
using this mapfile (restricted to LAYER definition)
LAYER
NAME 'JRC_SRTM90'
TYPE 'RASTER'
DATA
'/home/data/datasets/public/srtm90/mapserver/eea_r_3035_100_m_srtm90-dem_2000_grid/srtm90_dem100'
METADATA
## WMS ##
'wms_title' 'SRTM Digital Elevation Model'
'wms_abstract' 'Shuttle Radar Topography Mission (SRTM) data
is a high quality elevation data for large portions and areas of the world.'
'wms_label' 'SRTM_90_info'
'wms_metadataurl_format' 'text/html'
'wms_extent' '-180 -90 180 90'
'wms_enable_request' '*'
'wms_include_items' 'all'
'gml_include_items' 'all'
## WCS ##
'wcs_title' 'SRTM Digital Elevation Model'
'gml_featureid' 'ID' ## REQUIRED
'wcs_label' 'SRTM_90'
'wcs_description' 'Shuttle Radar Topography Mission (SRTM)
data is a high quality elevation data for large portions and areas of the
world.'
'wcs_formats' 'AIGRID'
'wcs_extent' '-180 -90 180 90'
'wcs_enable_request' '*'
"wcs_rangeset_name" "Range 1" ### required to support
DescribeCoverage request
"wcs_rangeset_label" "Bluemarble classes" ### required to
support DescribeCoverage request
END #end metadata
STATUS OFF
DUMP TRUE
TEMPLATE ' '
PROJECTION
'init=epsg:4326'
END
END #end layer
I am doing WMS request by pointing to ArcInfo srtm90_dem100 directory (that
contains adf files) but I have no response from MapServer.
Attending to Apache logs:
[Mon Jul 23 17:03:05 2012] [error] [client 158.109.144.146] GDAL:
GDALDeregister_GTiff() called.
[Mon Jul 23 17:03:06 2012] [error] [client 158.109.144.146] File does not
exist: /var/www/favicon.ico
[Mon Jul 23 17:03:08 2012] [error] [client 158.109.144.146] GDAL:
GDALOpen(/home/data/datasets/public/eea/srtm90/mapserver/eea_r_3035_100_m_srtm90-dem_2000_grid/srtm90_dem100.aux,
this=0x2461bc0) succeeds as HFA.
GDALOpen(/home/data/datasets/public/eea/srtm90/mapserver/eea_r_3035_100_m_srtm90-dem_2000_grid/srtm90_dem100,
this=0x24414e0) succeeds as AIG.
[Mon Jul 23 17:03:09 2012] [error] [client 158.109.144.146] GDAL:
[Mon Jul 23 17:03:09 2012] [error] [client 158.109.144.146] File does not
It seems to use drivers correctly.
I have OUTPUTFORMAT definition like this:
# GRID COVERAGE
OUTPUTFORMAT
NAME 'AIGRID'
DRIVER 'GDAL/AAIGRID'
## MIMETYPE 'image/x-aigrid'
IMAGEMODE 'INT16'
EXTENSION 'grd'
## FORMATOPTION 'FILENAME=result.grd'
END #end outputformat
Does anybody know why there is no response in my situation? Or send some
clues for publishing ArcInfo Grids using GDAL? I have not found any info
relevant for me about this issue.
Thank you in advance
Jorge
View this message in context: http://osgeo-org.1560.n6.nabble.com/ArcInfo-Grid-with-MapServer-tp4990112.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
