[mapserver-users] ArcInfo Grid with MapServer
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Mon Jul 23 08:11:43 PDT 2012
STATUS OFF means that the layer is turned off. DEFAULT sets it to be allways ON and "STATUS ON" means it can be on or off depending from your request. Byt the way, how does your request look like?
-Jukka Rahkonen-
________________________________________
Lähettäjä: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org] käyttäjän jorgelopez [jorgelopez.physics at gmail.com] puolesta
Lähetetty: 23. heinäkuuta 2012 18:04
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: [mapserver-users] ArcInfo Grid with MapServer
Hello everyone:
I have some problems trying to render Arc Info Grids with MapServer. I am
using this mapfile (restricted to LAYER definition)
LAYER
NAME 'JRC_SRTM90'
TYPE 'RASTER'
DATA
'/home/data/datasets/public/srtm90/mapserver/eea_r_3035_100_m_srtm90-dem_2000_grid/srtm90_dem100'
METADATA
## WMS ##
'wms_title' 'SRTM Digital Elevation Model'
'wms_abstract' 'Shuttle Radar Topography Mission (SRTM) data
is a high quality elevation data for large portions and areas of the world.'
'wms_label' 'SRTM_90_info'
'wms_metadataurl_format' 'text/html'
'wms_extent' '-180 -90 180 90'
'wms_enable_request' '*'
'wms_include_items' 'all'
'gml_include_items' 'all'
## WCS ##
'wcs_title' 'SRTM Digital Elevation Model'
'gml_featureid' 'ID' ## REQUIRED
'wcs_label' 'SRTM_90'
'wcs_description' 'Shuttle Radar Topography Mission (SRTM)
data is a high quality elevation data for large portions and areas of the
world.'
'wcs_formats' 'AIGRID'
'wcs_extent' '-180 -90 180 90'
'wcs_enable_request' '*'
"wcs_rangeset_name" "Range 1" ### required to support
DescribeCoverage request
"wcs_rangeset_label" "Bluemarble classes" ### required to
support DescribeCoverage request
END #end metadata
STATUS OFF
DUMP TRUE
TEMPLATE ' '
PROJECTION
'init=epsg:4326'
END
END #end layer
I am doing WMS request by pointing to ArcInfo srtm90_dem100 directory (that
contains adf files) but I have no response from MapServer.
Attending to Apache logs:
[Mon Jul 23 17:03:05 2012] [error] [client 158.109.144.146] GDAL:
GDALDeregister_GTiff() called.
[Mon Jul 23 17:03:06 2012] [error] [client 158.109.144.146] File does not
exist: /var/www/favicon.ico
[Mon Jul 23 17:03:08 2012] [error] [client 158.109.144.146] GDAL:
GDALOpen(/home/data/datasets/public/eea/srtm90/mapserver/eea_r_3035_100_m_srtm90-dem_2000_grid/srtm90_dem100.aux,
this=0x2461bc0) succeeds as HFA.
GDALOpen(/home/data/datasets/public/eea/srtm90/mapserver/eea_r_3035_100_m_srtm90-dem_2000_grid/srtm90_dem100,
this=0x24414e0) succeeds as AIG.
[Mon Jul 23 17:03:09 2012] [error] [client 158.109.144.146] GDAL:
[Mon Jul 23 17:03:09 2012] [error] [client 158.109.144.146] File does not
It seems to use drivers correctly.
I have OUTPUTFORMAT definition like this:
# GRID COVERAGE
OUTPUTFORMAT
NAME 'AIGRID'
DRIVER 'GDAL/AAIGRID'
## MIMETYPE 'image/x-aigrid'
IMAGEMODE 'INT16'
EXTENSION 'grd'
## FORMATOPTION 'FILENAME=result.grd'
END #end outputformat
Does anybody know why there is no response in my situation? Or send some
clues for publishing ArcInfo Grids using GDAL? I have not found any info
relevant for me about this issue.
Thank you in advance
Jorge
View this message in context: http://osgeo-org.1560.n6.nabble.com/ArcInfo-Grid-with-MapServer-tp4990112.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
