[mapserver-users] Resolution of PDF Output
Tim-Hinnerk Heuer
heuert at landcareresearch.co.nz
Tue Jul 24 04:09:47 PDT 2012
Hi Thomas,
Does Mapserver support PDF output? What about marginalia?
Regards,
Tim
On Tue, Jul 24, 2012 at 10:11 PM, thomas bonfort <thomas.bonfort at gmail.com<mailto:thomas.bonfort at gmail.com>> wrote:
The pdf is problably generated at 72 dpi, i.e. approx 28 pixels/cm
1000 pixels / (28 pixels/cm) = 35.71 cm, i.e. with rounding occuring
close to your 352 mm.
reagrds,
thomas
On Tue, Jul 24, 2012 at 12:06 PM, Sven Geggus
<lists at fuchsschwanzdomain.de<mailto:lists at fuchsschwanzdomain.de>> wrote:
> Hello,
> for PDF generation I would usually like to output Data in Papersizes (A3,
> A4, ...) but in shp2img or CGI Interface I can only specify pixels.
> How does this size correspond to the size shown in acrobat reader?
> If I take 1000 Pixels this will result in 352.8mm
> Where does this factor of 2.838 originate from?
> Regards
> Sven
> .. this message has been created using an outdated OS (UNIX-like) with an
> outdated mail- or newsreader (text-only) :-P
> /me is giggls at ircnet, http://sven.gegg.us/ on the Web
> mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
Tim-Hinnerk Heuer
Web Developer
Landcare Research (http://www.landcareresearch.co.nz)
Informatics (http://wiki.zen.landcareresearch.co.nz)
Ph: +64 6 353 4872
Please consider the environment before printing this email
Warning: This electronic message together with any attachments is confidential. If you receive it in error: (i) you must not read, use, disclose, copy or retain it; (ii) please contact the sender immediately by reply email and then delete the emails.
The views expressed in this email may not be those of Landcare Research New Zealand Limited. http://www.landcareresearch.co.nz
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120724/905a08a8/attachment.html>
