[mapserver-users] Mapserver Template - BBOX
Donald Kerr
donald.kerr at dkerr.co.uk
Tue Jul 24 10:17:30 PDT 2012
Steve,
"[rawext]" has the same limitations as "[mapext]" which provides the overall
extents as defined in the map file.
I have created a ticket as you suggested:
https://github.com/mapserver/mapserver/issues/4405
Many thanks.
Regards,
Donald
-----Original Message-----
From: Lime, Steve D (DNR) [mailto:Steve.Lime at state.mn.us]
Sent: 24 July 2012 16:07
To: Donald Kerr; 'Eichner, Andreas - SID-NLKM';
mapserver-users at lists.osgeo.org
Subject: RE: [mapserver-users] Mapserver Template - BBOX
Wonder if [rawext] will work? Worth a quick try but I doubt it. That value
will get you the un-altered extent used for map draws or queries but only
through CGI calls.
I think what's happening is that because WFS works generally outside the CGI
object that that some of the tracking
variables referenced by the template code aren't being populated.
The fix is relatively easy but there are a number of ways to go about it.
Donald, can you create a ticket so this
can get into 6.2 (I hope)...
Steve
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Donald Kerr
Sent: Tuesday, July 24, 2012 7:26 AM
To: 'Eichner, Andreas - SID-NLKM'; mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Mapserver Template - BBOX
Andreas,
Thanks, but this only works for the individual features within [resultset].
I need to get the BBOX values which is basicallly the overall bounds of the
query. [mapext] doesn't work either as that takes the bounds from the map
file which are much greater than the BBOX for the query.
Many thanks.
Regards,
Donald
From: Eichner, Andreas - SID-NLKM [mailto:Andreas.Eichner at sid.sachsen.de]
Sent: 24 July 2012 12:35
To: Donald Kerr; mapserver-users at lists.osgeo.org
Subject: AW: [mapserver-users] Mapserver Template - BBOX
You might try:
[shpminx], [shpminy], [shpmaxx], [shpmaxy]
Minimum / maximum X or Y coordinate of shape extent. Available only when
processing query results.
See http://mapserver.org/mapfile/template.html#query
HTH
> -----Ursprüngliche Nachricht-----
> Von: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Im Auftrag
> von Donald Kerr
> Gesendet: Dienstag, 24. Juli 2012 11:57
> An: mapserver-users at lists.osgeo.org
> Betreff: [mapserver-users] Mapserver Template - BBOX
> Hi list,
> I am trying to use BBOX in a WFS query template where I need to get
> the minx, miny etc in the following format:
> "258481,665862 258607,665956" i.e. a space between coordinate pairs
> which are separated by a comma.
> In the template, [bbox] returns "258481,665862,258607,665956" with
> each value separated by a comma.
> I have tried "[bbox.minx],[bbox.miny] [bbox.maxx],[bbox.maxy]" without
> success.
> Is there a way to achieve what I am looking for?
> Many thanks.
> Regards,
> Donald
