[mapserver-users] Mapserver as wms client
Sowmya Tiramdasu
stiramdasu at qcoherent.com
Wed Jul 25 10:04:31 PDT 2012
Hi Jeff,
Sorry for the previous email. I got the Utility running now. I am checking
where the problem is . Will let you know if I have further questions.
Thank you very much for your help!
Thanks,
Sowmya.
_______________________________
Sowmya Tiramdasu
QCoherent Software
9668 Madison Blvd., Suite 202
Madison, AL 35758
(256) 461-8289 Telephone
(256) 461-8249 Fax
www.geocue.com
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Sowmya
Tiramdasu
Sent: Wednesday, July 25, 2012 11:47 AM
To: 'Jeff McKenna'; mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Mapserver as wms client
Hi Jeff,
Thanks for the reply. I think that should work. But, I am having a problem
running the utility. The error is : The program can not start because
libmap.dll is missing from your computer. Try reinstalling the program to
fix the problem.
I went and checked in my C:\ms4w\Apache\cgi-bin folder and libmap.dll is
present. I also ran the setenv.bat before running the utility. Can you
please guide me how to get this utility running?
Thanks in advance!
Sowmya.
Sowmya Tiramdasu
QCoherent Software
Madison, AL 35758
(256) 461-8249 Fax
www.geocue.com
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Jeff McKenna
Sent: Wednesday, July 25, 2012 9:31 AM
To: mapserver-users at lists.osgeo.org
On 12-07-24 7:13 PM, Sowmya Tiramdasu wrote:
> Hi,
> I configures map server to act as a WMS Client. But it doesn't work as
> expected. When i make a getMap request to my WMS server I get the right
> image back but when I try to make it a layer through my map server it is
> not working.
> I am using fiddler to see all the calls made to the server. I see the
> request I am sending to the map server but do not see a request to my
> WMS Server( I thought when Map server tries to consume the WMS server,
> it sends a request to the WMS Server- which should be shown in fiddler)
A very easy way to see all of the WMS requests, is to use the included
"shp2img" commandline utility with the "-all_debug 5" option
(http://www.mapserver.org/utilities/shp2img.html), MS4W users can call
this utility after executing 'setenv.bat' in the same command window.
For example, the command could be:
shp2img -m demo_wms.map -o ttt.png -all_debug 5
and the results would be:
msLoadMap(): 0.003s
msDrawMap(): rendering using outputformat named jpeg (AGG/JPEG).
HTTP: Starting to prepare HTTP requests.
Using CURL_CA_BUNDLE=\ms4w\Apache\conf\ca-bundle\cacert.pem
HTTP request: id=0, http://demo.mapserver.org/cgi-bin
/wms?LAYERS=country_bounds&REQUEST=Ge
tMap&SERVICE=WMS&FORMAT=image/gif&STYLES=&HEIGHT=300&VERSION=1.1.1&SRS=EPSG:
4326&WIDTH=400
&BBOX=-180.451127819549,-135.338345864662,180.451127819549,135.338345864662&
TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_inimage
HTTP: Before download loop
msHTTPWriteFct(id=0, 1306 bytes)
msHTTPWriteFct(id=0, 2748 bytes)
HTTP: After download loop
msHTTPExecuteRequests() timing summary per layer (connect_time +
time_to_first_packet + download_time = total_time in seconds)
Layer 0: 0.109 + 0.624 + 0.203 = 0.936s
msDrawMap(): WMS/WFS set-up and query, 0.857s
msDrawRasterLayerLow(country_bounds): entering.
msDrawRasterLayerGDAL(): red,green,blue,alpha bands = 1,0,0,0
msDrawMap(): Layer 0 (country_bounds), 0.007s
msDrawMap(): Drawing Label Cache, 0.000s
msDrawMap() total time: 0.869s
msSaveImage(ttt.png) total time: 0.009s
msFreeMap(): freeing map at 026ED540.
freeLayer(): freeing layer at 036C3850.
shp2img total time: 0.886s
I hope that helps.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
