[mapserver-users] Resolution of PDF Output
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Jul 25 10:18:56 PDT 2012
On 7/25/2012 11:34 AM, Sven Geggus wrote:
> Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
>> set the RESOLUTION to an appropriate value for your PDF.
> This does not work for PDF. Regardless of the RESOLUTION in the Mapfile the
> generated PDF Files are always generated with 72 DPI.
> Same with SVG BTW. Looks like all cairo output is affected. Should I report
> this as a bug?
> Sven
Hi Sven,
What version are you using? have you tried this with the 6.2-beta?
Sounds like this should be reported as a bug if it does not already have
a ticket and post the bug number here so people can add themselves to
the cc list to track it.
Hi Thomas,
Is this a known issue? Is it resolved in 6.2 or is there a work around.
Thanks,
-Steve W
