[mapserver-users] Mapserver as wms client error trace
Sowmya Tiramdasu
stiramdasu at qcoherent.com
Wed Jul 25 15:16:12 PDT 2012
Hi Jeff,
Just to let you know. I got it working :)
The problem was with an entry in the shape file. Under the WMS meta data , I
gave wms_latlonboundingbox value as my extent. Ideally it should have been
wms_extent feature. So was this projection problem.
Thanks again for all your guidance, I learnt many things!
Thanks,
Sowmya.
_______________________________
Sowmya Tiramdasu
QCoherent Software
9668 Madison Blvd., Suite 202
Madison, AL 35758
(256) 461-8289 Telephone
(256) 461-8249 Fax
www.geocue.com
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Sowmya
Tiramdasu
Sent: Wednesday, July 25, 2012 3:50 PM
To: 'Jeff McKenna'; mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Mapserver as wms client error trace
Hi Jeff,
Thanks for your reply. Yes, I tried the example ones and it works fine. The
problem is only with my WMS Server. The data I have( shape files, ortho
images and the Las file[This is being rendered by my WMS Server]) are all in
the same projection and I gave the extents of the map also accordingly. With
the same projection and extents I am able to render the ortho images and
shape files using map server, but not able to render the image from my WMS
Server.
How can I check if my extents are right and the projection information I
provided is right ? Are there any Tips or best practices to achieve this?
Also, can you guide me to a good tutorial where I can understand all this
projection stuff. I am fairly new to GIS domain.
Thanks again for your patience in trying to help me. Appreciate your help.
Regards,
Sowmya.
Sowmya Tiramdasu
QCoherent Software
Madison, AL 35758
(256) 461-8249 Fax
www.geocue.com
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Jeff McKenna
Sent: Wednesday, July 25, 2012 3:18 PM
To: mapserver-users at lists.osgeo.org
Hello Sowmya,
Next I would probably test by adding a known working WMS server into
your mapfile: you can use the exact example from the docs here (just add
a projection object)
http://www.mapserver.org/ogc/wms_client.html#adding-a-wms-layer If
shp2img shows a GetMap for that new layer, then you know it's a problem
with your WMS Server (or a problem regarding coordinates).
If all else fails, make a copy of your mapfile, then remove all other
layers from it, and any projection objects, and make sure your EXTENT
and UNITS match the coordinates of your WMS layer.
(yes projections are the hardest part of web mapping)
Good luck,
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 12-07-25 2:35 PM, Sowmya Tiramdasu wrote:
> Hi,
> I checked the trace after running the shp2img.exe. I see that there is
no
> call made to my wms server. There is a re-projection error seems like. All
> the ortho images and output from shape files is coming good.Only the layer
> from my WMS server is not being rendered. Here is my mapfile and the error
> log.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
