[mapserver-users] MapServer and PHP
Henrique Rennó
henrique.renno at gmail.com
Mon Jul 30 06:40:17 PDT 2012
I'll try setting everything up with the installer later. Maybe the problem
with the zip file is that it needs some configuration by hand.
2012/7/30 Lester Caine <lester at lsces.co.uk>
> Henrique Rennó wrote:
>> The mime section contains AddType and Action set to .php
>> and /cgi-bin/php-cgi.exe. What could be the problem?
>> What is ScriptAlias set to?
>> Using php as CGI usually means that it's pointing to the PHP
>> directory,
>> which is where php-cgi.exe is located, but I'm fairly sure mapserver
>> uses
>> the conventional location for cgi-bin ... in the apache directory
>> I've been doing my own installations of
>> Apache/PHP/Firebird/Mapserver, so
>> haven't checked out the 'default' recently ...
>> Thanks for your reply. The ScriptAlias seems to be right: ScriptAlias
>> /cgi-bin/
>> "/ms4w/Apache/cgi-bin/"
>> I never used or configured Apache and PHP, so I'm a little lost, but the
>> website
>> said ms4w would have everything properly configured, so I didn't bother
>> with
>> these. Do you think the only solution would be to configure manually both
>> Apache
>> and PHP?
> That is sort of what I was expecting ... but is php-cgi.exe located in
> that directory? Having PHP running with Apache is normally the starting
> point before adding Mapserver, so WAS PHP working ... you probably did not
> test?
> Personally I run php as an apache module ...
> in httpd,conf
> LoadModule php5_module c:\Network\PHP5\php5apache2_2.**dll
> So I don't have to mix up with the cgi stuff, but it depends on which
> version you downloaded ...
> 6.0.3? It might be worth trying the installer instead. PHP is an option as
> far as I can see, so would need to be enabled while installing. I'm just
> grabbing a copy of the zip so I can check it out anyway.
> Lester Caine - G8HFL
> Contact - http://lsces.co.uk/wiki/?page=**contact<http://lsces.co.uk/wiki/?page=contact>
> L.S.Caine Electronic Services - http://lsces.co.uk
> EnquirySolve - http://enquirysolve.com/
> Model Engineers Digital Workshop - http://medw.co.uk
> Rainbow Digital Media - http://rainbowdigitalmedia.co.**uk<http://rainbowdigitalmedia.co.uk>
> ______________________________**_________________
> mapserver-users at lists.osgeo.**org <mapserver-users at lists.osgeo.org>
> http://lists.osgeo.org/**mailman/listinfo/mapserver-**users<http://lists.osgeo.org/mailman/listinfo/mapserver-users>
Henrique
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120730/c2c10f26/attachment.html>
