[mapserver-users] GetStyles SLD does not include Opacity value
myOpenLayersUName
joanne.mcgraw at SYMPATICO.CA
Mon Jun 4 12:35:15 PDT 2012
Hello everyone,
I have a Map file with a polygon layer that has an OPACITY value of 20
defined as:
I see a correctly opaque display when I do a GetMap or a GetLegendGraphic,
so I know the OPACITY value is set properly. However, when I perform a
GetStyles request, the returned SLD doesn't include anything about the
opacity. The response is:
Am I wrong to expect to see a "fill-opacity" CssParameter for this layer? I
am using Mapserver 6.0.1 and, since it might have some bearing of this
question, the OUTPUTFORMAT for the map is defined as follows:
If there is some pointers someone can offer to get this information returned
properly, I'd appreciate it.
Cheers,
jtm
View this message in context: http://osgeo-org.1560.n6.nabble.com/GetStyles-SLD-does-not-include-Opacity-value-tp4979066.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
