[mapserver-users] ecw problems
stefano parodi
fanenji at gmail.com
Tue Jun 5 02:51:20 PDT 2012
Hi all.
I'm setting up a new mapserver application on Windows 2008 Server with IIS
7.
I've download the win32 binaries from http://www.gisinternals.com
(release-1600-gdal-1-9-mapserver-6-0)
that come with ECW support.
I'm able to use the ECW files with both gdalinfo and the shp2img utility
app, tha produce a valid png image, but not with the mapserver cgi.
Mapserver CGI work well with both Oracle Spatial and PostGIS layers but
simply return the mapserver executable (mapserv.exe) in case of a ECW layer.
Mapserver log doesn't report any error, here's an extract from the log:
[Fri Jun 01 16:27:17 2012].912000 CGI Request 1 on process 3872
[Fri Jun 01 16:27:17 2012].914000 msDrawMap(): rendering using outputformat
named png (AGG/PNG).
[Fri Jun 01 16:27:17 2012].915000 msDrawMap(): WMS/WFS set-up and query,
0.001s
[Fri Jun 01 16:27:17 2012].940000 msDrawRasterLayerLow(ORTOFOTO_2007):
entering.
[Fri Jun 01 16:27:18 2012].560000 msDrawMap(): Layer 5 (ORTOFOTO_2007),
0.645s
[Fri Jun 01 16:27:18 2012].560000 msDrawMap(): Drawing Label Cache, 0.000s
[Fri Jun 01 16:27:18 2012].560000 msDrawMap() total time: 0.647s
[Fri Jun 01 16:27:18 2012].906000 msSaveImage(stdout) total time: 0.346s
[Fri Jun 01 16:27:18 2012].906000 mapserv request processing time
(msLoadMap not incl.): 0.994s
[Fri Jun 01 16:27:18 2012].906000 msFreeMap(): freeing map at 0057FA70.
Does someone has any clue about what's happening?
Thank you in advance.
Stefano Parodi.
Geospatial Developer at Datasiel S.p.A.
http://it.linkedin.com/in/stefanoparodi
http://twitter.com/fanenji <https://twitter.com/#!/fanenji>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120605/86cce74f/attachment.html>
