[mapserver-users] AGG: Internal vs. External
Alberto Najera
anajera at bicimapas.com.mx
Tue Jun 5 07:23:13 PDT 2012
Hello
I am using Mapserver as a WMS server and would like to improve the rendered
image quality. Currently we get jagged lines and poor text rendering as you
can see in this link
http://www.bicimapas.com.mx/SpatiaRetail.html
Source are SHP files. We plan to use AGG to improve this and are using
Mapserver 6.01. I have not installed AGG but when running /.configure it
shows AGG Support: Internal and with ./mapserv -v shows SUPPORTS: AGG.
The question is whether there is a difference between internal or external
AGG support? Is this internal AGG support provided by GD? Finally, is
there a suggestion on how to improve the image rendering quality?
The map file has this image rendering setting:
MAP
NAME "DemoFerre"
UNITS dd
SIZE 640 480
IMAGECOLOR 244 244 244
IMAGETYPE png
SHAPEPATH "/home/bicimapas/mapdata/"
EXTENT -99.070427 17.869010 -96.723984 20.839951
FONTSET "/home/bicimapas/mapdata/fontset.txt"
Thanks in advance
Alberto Najera
