[mapserver-users] AGG: Internal vs. External
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Tue Jun 5 07:40:54 PDT 2012
MapServer ships with AGG and it's built by default. I believe in 6.0 the "PNG" output format references GD. If you want to use AGG try "PNG24" instead or roll your own OUTPUTFORMAT block.
Steve
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Alberto Najera
Sent: Tuesday, June 05, 2012 9:23 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] AGG: Internal vs. External
Hello
I am using Mapserver as a WMS server and would like to improve the rendered image quality. Currently we get jagged lines and poor text rendering as you can see in this link
http://www.bicimapas.com.mx/SpatiaRetail.html
Source are SHP files. We plan to use AGG to improve this and are using Mapserver 6.01. I have not installed AGG but when running /.configure it shows AGG Support: Internal and with ./mapserv -v shows SUPPORTS: AGG.
The question is whether there is a difference between internal or external
AGG support? Is this internal AGG support provided by GD? Finally, is
there a suggestion on how to improve the image rendering quality?
The map file has this image rendering setting:
MAP
NAME "DemoFerre"
UNITS dd
SIZE 640 480
IMAGECOLOR 244 244 244
IMAGETYPE png
SHAPEPATH "/home/bicimapas/mapdata/"
EXTENT -99.070427 17.869010 -96.723984 20.839951 FONTSET "/home/bicimapas/mapdata/fontset.txt"
Thanks in advance
Alberto Najera
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
