[mapserver-users] GetStyles SLD does not include Opacity value
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Tue Jun 5 07:48:10 PDT 2012
Hi Joanne: What happens if you move the opacity into the class style?
Steve
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of myOpenLayersUName
Sent: Tuesday, June 05, 2012 9:32 AM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] GetStyles SLD does not include Opacity value
"Are we missing a few things like the response and the mapfile snippet? Also are you talking layer opacity or style opacity?"
I guess the email-er that sent around the post didn't include anything within the "raw" tags. Here's the full text again (without the tags):
I have a Map file with a polygon layer that has an OPACITY value of 20 defined as:
LAYER
NAME "Poly_wOpacity"
TYPE POLYGON
OPACITY 20
STATUS ON
PROJECTION
"init=epsg:3857"
END
INCLUDE "../../../mapserv/conf/sdeconnection.inc.map"
DATA "...,SHAPE,SDE.DEFAULT"
METADATA
"wms_title" "Polygon Layer w/Opacity of 20"
"wms_srs" "epsg:3857"
END
CLASS
NAME "Polygon Layer w/Opacity of 20"
STYLE
COLOR 255 0 0
END
END
END
I see a correctly opaque display when I do a GetMap or a GetLegendGraphic, so I know the OPACITY value is set properly. However, when I perform a GetStyles request, the returned SLD doesn't include anything about the opacity. The response is:
<StyledLayerDescriptor version="1.0.0" ...>
<NamedLayer>
<Name>Poly_wOpacity</Name>
<UserStyle>
<FeatureTypeStyle>
<Rule>
<Name>Polygon Layer w/Opacity of 20</Name>
<PolygonSymbolizer>
<Fill>
<CssParameter name="fill">#ff0000</CssParameter>
</Fill>
</PolygonSymbolizer>
</Rule>
</FeatureTypeStyle>
</UserStyle>
</NamedLayer>
</StyledLayerDescriptor>
Am I wrong to expect to see a "fill-opacity" CssParameter for this layer? I am using Mapserver 6.0.1 and, since it might have some bearing of this question, the OUTPUTFORMAT for the map is defined as follows:
OUTPUTFORMAT
NAME png32
DRIVER "AGG/PNG"
MIMETYPE "image/png"
IMAGEMODE RGBA
EXTENSION png
FORMATOPTION "INTERLACE=OFF"
TRANSPARENT ON
END
If there is some pointers someone can offer to get this information returned properly, I'd appreciate it.
Cheers,
jtm
View this message in context: http://osgeo-org.1560.n6.nabble.com/GetStyles-SLD-does-not-include-Opacity-value-tp4979066p4979230.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
