[mapserver-users] File size of generated PNG
SQ9MEV
groups at sq9mev.info
Sat Jun 9 22:58:07 PDT 2012
On 09.06.2012 10:08, Rahkonen Jukka wrote:
> Hi,
> Have you already tried quantize and compression options from http://www.mapserver.org/mapfile/outputformat.html? The "png8" example is a good starting point.
> How does your current png outputformat look?
I've faced this problem some time ago - i wanted fancy transparent
tiles. The solution was to use paletted PNG:
OUTPUTFORMAT
NAME "png"
DRIVER AGG/PNG
IMAGEMODE RGBA
FORMATOPTION "PALETTE_FORCE=TRUE"
FORMATOPTION "PALETTE=/[...]/palette.txt"
INCLUDE "palette.map"
FORMATOPTION "INTERLACE=OFF"
END
That decreased non empty file size from avrerage ~13KB to 2..3kB, empty
pngs are bigger ofcourse (AFAIR 1.8KB paletted vs 332B not paletted).
I use custom django views using some parts of tilecache - tilecache must
be patched to use transaprency in palette:
https://github.com/sq9mev/TileCache/commit/cd718fae9d8da01673c842b0b89226bb8ba4697f
And you have to use development version of PIL:
https://bitbucket.org/effbot/pil-2009-raclette
And you need to prepare your palette as well.
Regards
Bartek
