[mapserver-users] Anaimated images as map sources
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Tue Jun 12 14:24:03 PDT 2012
I'm not an AGG expert but that's probably not the component in play here anyway. Presumably whatever the source imagery it would/should be considered a raster dataset. I guess I'd look into how GDAL deals with animated input and then figure out if that can be configured through MapServer. I guess it wouldn't surprise me if GDAL considered individual frames as bands. Maybe that's the way to think about.
Steve
Sent: Tuesday, June 12, 2012 4:18 PM
To: Lime, Steve D (DNR)
Subject: RE: Anaimated images as map sources
Hi Steve,
So,
What AGG functions are used in MapServer? I just went looking for what AGG stood for. Found some animation examples, but they were final constructs, not specifically clipping an existing animated image.
What I was going to attempt, was to to try and set up a animated image from NOAA as a data source for Mapserver. They have the separate images available as well, which I would need to assemble after clipping into a image, Hmmm, maybe a layer per time index, ten hit that from the CGI through MapServer, then into a animated image for use in the map. Still sounds clunky though.
bobb
Sent: Tuesday, June 12, 2012 4:05 PM
bobb
Sent: Tuesday, June 12, 2012 4:03 PM
To: Basques, Bob (CI-StPaul); mapserver-users at osgeo.org<mailto:mapserver-users at osgeo.org>
Not that I'm aware of.
From: mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Basques, Bob (CI-StPaul)
Sent: Tuesday, June 12, 2012 4:02 PM
To: mapserver-users at osgeo.org<mailto:mapserver-users at osgeo.org>
Subject: [mapserver-users] Anaimated images as map sources
All,
Can Mapserver slice and dice an Animated (GIF or PN or ??) map source image and return a resulting animated image?
I found a refernce to it NOT owrking for a WMS to WMS call where the upstream WMS service would produce a Animated GIF, but the downstream Mapserver WMS client would only see (present) the first frame of the animation.
Thanks
bobb
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120612/a176d8ff/attachment-0001.html>
