[mapserver-users] Mapscript Java Interface for 64 Bit Java Version?
Umberto Nicoletti
umberto.nicoletti at gmail.com
Wed Jun 13 00:08:14 PDT 2012
Tamas, thanks for the link.
Recently I was working on:
https://github.com/mapserver/mapserver/issues/4231
and had some trouble with Windows builds because I simply don't have a
build env for Windows and had to ask jmckenna to pull and build for me.
So I ended up with a gcc only fix.
Any chance that I can use the build tools ot that link so that I can fix
the issue for Windows too?
Cheers,
Umberto
On Wed, Jun 13, 2012 at 9:01 AM, Tamas Szekeres <szekerest at gmail.com> wrote:
> Jacob,
> As far as I remember the gisinternals build server compiles java mapscript
> for x64.
> http://www.gisinternals.com/sdk/
> Best regards,
> Tamas
> 2012/6/11 Jacob Mendt <Jacob.Mendt at mailbox.tu-dresden.de>
>> Hello List.****
>> I appreciate the work which is done around the mapserver. Right now I try
>> to use the java mapscript interface and I got the following issue.****
>> I already got the java mapscript interface running. But right now it is
>> only working with a 32-bit java version. My question is now, if there is
>> also any support for 64-bit java version? ****
>> My runtime environment is:****
>> - Windows 7 (64 bit)****
>> - MS4W v3.0.2 packet (Mapscript 5.6.6.)****
>> - Java Version: 1.7.0_0.4 (32-bit)****
>> I am looking forward to hear from you.****
>> Kind regards,****
>> JM****
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120613/3d6d1abd/attachment.html>
