[mapserver-users] shortest_path query
Eichner, Andreas - SID-NLKM
Andreas.Eichner at sid.sachsen.de
Wed Jun 13 04:53:29 PDT 2012
You need to create a LineString geometry using a spatial aggregate like ST_MakeLine() first. Consider reading the pgRouting documentation, f.e. http://www.pgrouting.org/docs/howto/mapserver.html
> -----Ursprüngliche Nachricht-----
> Von: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Im Auftrag
> von Annu Anurag
> Gesendet: Dienstag, 12. Juni 2012 19:55
> An: mapserver-users
> Betreff: [mapserver-users] shortest_path query
> Hello there. I've got the query for shortest path using
> pgrouting to run finally. I get the edges but now I need to
> map my result onto a mapserver layer. I've tried examples
> from the internet but mostly they're flawed. I'm positng the
> query which has worked for me. Please suggest a way to
> convert it into a visible layer using mapserver.
> SELECT * FROM shortest_path('SELECT gid AS id,
> fromnodeid::int4, tonodeid::int4, length0::float8 AS cost
> FROM edges_line', 35, 210, false, false)
> I tried to form a query-layer but failed. I'm sending the
> code I used to. Please correct me.
> DATA "the_geom FROM (SELECT * FROM shortest_path('SELECT gid
> AS id, fromnodeid::int4, tonodeid::int4, length0::float8 AS
> cost FROM edges_line', 35, 210, false, false)) AS foo using
> unique gid using srid=4326"
> Here is the layer definition:
> LAYER
> NAME "route"
> CONNECTIONTYPE postgis
> CONNECTION "user=postgres password=***********
> dbname=VSDelhidb host=localhost"
> DEBUG 5
> STATUS DEFAULT
> TYPE LINE
> shortest_path('SELECT gid AS id, fromnodeid::int4,
> tonodeid::int4, length0::float8 AS cost FROM edges_line', 35,
> 210, false, false)) AS foo using unique gid using srid=4326"
> TEMPLATE "t"
> //////////////////////////////////////////////////////THE
> CLASS THAT CLASSIFIES EVERYTHING IN IT.
> CLASS
> STYLE OF DRAWING THIS CLASS. ////////////////////////////////////
> NAME "0"
> STYLE
> SYMBOL "circle"
> SIZE 10
> OUTLINECOLOR 255 0 0
> COLOR 165 42 42
> END #___END OF THE SYLE DECLARATION FOR THIS
> CLASS.___#####################################################
> END #_________END OF THE CLASS THAT CLASSIFIES
> EVERYTHING.___________########################################
> END #________END OF THE LAYER THAT DRAWS
> EVERYTHING._________##########################################
