[mapserver-users] Projection
Thomas Hofmann
thomas at savoy-truffle.de
Thu Jun 14 07:39:28 PDT 2012
Hello,
currently I am working on a map displaying the distiribution of a name
(surname/forename/location name) in Germany. For that purpose
mapserver (v. 5.6.5) and php-mapscript is used.
The underlying geographic information is from a public domain
shapefile containing postcode (PLZ) regions of germany:
http://www.metaspatial.net/download/plz.tar.gz
Details on that data in german:
http://arnulf.us/PLZ
There the data is described as originally been in "Gauß Krüger
3-Streifen", but the shapefile's data as beeing converted to EPSG:4326
(WGS84).
The map should be rendered so that the width and height of germany are
more or less like here:
http://de.wikipedia.org/wiki/Datei:Deutschland_politisch_2010.png
Without configured projections it looks like:
https://www.dropbox.com/s/n1uobhd12xhsf4u/1ee63112dc71c15f1247994883aebc42.png
So some projection is needed.
One question is, what projection would be appropriate, I suppose
something like "Alber's equal area" or "Gauß-Krüger zone 3" could do
the trick. But before that I would be glad if an arbitrary projection
would work at all...
The map-file as generated via mapscript looks like (cut to the
relevant part, as far as I understand it):
MAP
EXTENT 5.05686874304783 47.2 15.5931312569522 55.1
IMAGECOLOR 255 255 255
IMAGETYPE gif
SIZE 1200 900
STATUS ON
CONFIG PROJ_LIB "/usr/share/proj/"
NAME "Germany"
PROJECTION
"init=epsg:2166"
END
LAYER
NAME "0"
PROJECTION
"init=epsg:4326"
END
STATUS DEFAULT
TYPE POLYGON
UNITS METERS
CLASS
NAME "PLZ"
STYLE
ANGLE 360
COLOR 99 99 99
OUTLINECOLOR 0 0 0
SYMBOL 0
WIDTH 1
END
END
END
END
With this map-file the PLZ layer is not displayed. If omitting the
PROJECTION-section within the LAYER it is displayed.
For reference: the whole zipped mapfile, containing the data:
https://www.dropbox.com/s/sd65gc7dch7swh3/projection.complete.map.zip
So:
- What to do, to get projections working?
- What kind of projection would be appropriate?
Hints are most welcome.
Kind regards,
Thomas Hofmann
