[mapserver-users] Projection
Arnd Wippermann
arnd.wippermann at web.de
Thu Jun 14 13:53:49 PDT 2012
Your map extent should something like this
EXTENT 3186000 5210000 4006000 6156000
PROJECTION
"init=epsg:2166"
#or "init=epsg:31467"
END
then your layer should show.
Instead of Gauss-Krüger i would take EPSG:25832 (UTM32).
It's the new official used projection for Germany .
The layer will look the same as GK3.
Arnd
In Deutschland hat die Arbeitsgemeinschaft der Vermessungsverwaltungen der
Länder der Bundesrepublik Deutschland (AdV) im Jahre 1991 die Einführung des
ETRS89 als einheitliches amtliches Lagebezugssystem für ganz Deutschland
beschlossen.
(Quelle:http://de.wikipedia.org/wiki/Europ%C3%A4isches_Terrestrisches_Refere
nzsystem_1989)
-----Ursprüngliche Nachricht-----
Von: mapserver-users-bounces at lists.osgeo.org
[mailto:mapserver-users-bounces at lists.osgeo.org] Im Auftrag von Thomas
Hofmann
Gesendet: Donnerstag, 14. Juni 2012 16:39
An: mapserver-users at lists.osgeo.org
Betreff: [mapserver-users] Projection
Hello,
currently I am working on a map displaying the distiribution of a name
(surname/forename/location name) in Germany. For that purpose mapserver (v.
5.6.5) and php-mapscript is used.
The underlying geographic information is from a public domain shapefile
containing postcode (PLZ) regions of germany:
http://www.metaspatial.net/download/plz.tar.gz
Details on that data in german:
http://arnulf.us/PLZ
There the data is described as originally been in "Gauß Krüger 3-Streifen",
but the shapefile's data as beeing converted to EPSG:4326 (WGS84).
The map should be rendered so that the width and height of germany are more
or less like here:
http://de.wikipedia.org/wiki/Datei:Deutschland_politisch_2010.png
Without configured projections it looks like:
https://www.dropbox.com/s/n1uobhd12xhsf4u/1ee63112dc71c15f1247994883aebc42.p
ng
So some projection is needed.
One question is, what projection would be appropriate, I suppose something
like "Alber's equal area" or "Gauß-Krüger zone 3" could do the trick. But
before that I would be glad if an arbitrary projection would work at all...
The map-file as generated via mapscript looks like (cut to the relevant
part, as far as I understand it):
MAP
EXTENT 5.05686874304783 47.2 15.5931312569522 55.1
IMAGECOLOR 255 255 255
IMAGETYPE gif
SIZE 1200 900
STATUS ON
CONFIG PROJ_LIB "/usr/share/proj/"
NAME "Germany"
PROJECTION
"init=epsg:2166"
END
LAYER
NAME "0"
PROJECTION
"init=epsg:4326"
END
STATUS DEFAULT
TYPE POLYGON
UNITS METERS
CLASS
NAME "PLZ"
STYLE
ANGLE 360
COLOR 99 99 99
OUTLINECOLOR 0 0 0
SYMBOL 0
WIDTH 1
END
END
END
END
With this map-file the PLZ layer is not displayed. If omitting the
PROJECTION-section within the LAYER it is displayed.
For reference: the whole zipped mapfile, containing the data:
https://www.dropbox.com/s/sd65gc7dch7swh3/projection.complete.map.zip
So:
- What to do, to get projections working?
- What kind of projection would be appropriate?
Hints are most welcome.
Kind regards,
Thomas Hofmann
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
