[mapserver-users] Problems with query
Bistrais, Bob
Bob.Bistrais at maine.gov
Tue Jun 19 11:29:56 PDT 2012
I continue to have problems with querying layers as I migrate to newer software versions. Right now, I am moving an application to MS 6.0.2, MapScript 6.1, PHP 5.3.10.
I can display my layers properly. When I try to do a query I get an error. Here is the code:
$path = $info[2];
if(substr($path,0,1) == '.') {
$path = $CONFIGURATION['root'].$path;
$map = ms_newMapObj($path);
The $path looks correct if I echo it back.
Here is the error message:
Fatal error: Uncaught exception 'MapScriptException' with message 'Failed to open map file "/ms4w_304/apps/maptest/maps/./towns100.map"' in C:\ms4w_304\apps\maptest\htdocs\php\identify.php:127
It's also worth noting that this application works OK on a local machine. It's when I migrate it to a server that the trouble starts.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120619/b75d41ec/attachment.html>
