[mapserver-users] newbie just getting a blank page
Eloi Ribeiro
eloi.ribeiro at gmail.com
Tue Jun 26 06:18:03 PDT 2012
Thank you both. Now I'm seeing some light at the end of the tunnel. I got
my first request from MapServer work! You were both right CLASS, STATUS
were missing.
I started from the map file QGIS 1.8 MapServerExport tool output, but then
I made more modifications and probably got worst. So my responsibility for
not working properly. Anyway now a can start working from here.
Thanks!
This is how it looks now, still simple but working:
MAP
NAME "World map"
SIZE 900 700
UNITS meters
IMAGECOLOR 28 28 55
IMAGETYPE png
EXTENT -180 -90 180 90
PROJECTION
"proj=latlong"
"ellps=WGS84"
END
OUTPUTFORMAT
NAME png
DRIVER 'GD/PNG'
MIMETYPE 'image/png'
IMAGEMODE RGBA
EXTENSION 'png'
END
LAYER
STATUS DEFAULT
CONNECTIONTYPE POSTGIS
CONNECTION "dbname='bd_ceam' host='localhost' port='5432'
user='consulta' password='*******' sslmode='disable'"
DATA "geom FROM sch_sig.wd_paises USING UNIQUE gid USING srid=4326"
NAME "wd_paises"
CLASS
COLOR 10 20 50
END
TYPE POLYGON
END
END
END
Eloi Ribeiro
GIS Analyst
39,45º -0,40º
flavors.me/eloiribeiro
2012/6/26 Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>
> Hi,
> You do not ask for any layer. Add STATUS DEFAULT to your layer or add
> &layers=all into your request.
> Unfortunately, even your mapfile is short is has many other errors and
> outdated stuff. Where did you take an example when you wrote it?
> We should absolutely have some guaranteed correct mapfiles with
> corresponding data for the newbies and it should be forbidden for the poor
> new users to do any own trials before the Hello Word example shows a map.
> When I started we had MapLab but what do we have now? Even the Qgis
> mapfile write plugin is broken nowadays.
> -Jukka Rahkonen-
> ________________________________
> Eloi Ribeiro wrote:
> > Hi,
> > I'm trying MapServer for the first time and doing something wrong
> because all I get is a blank page<
> https://dl.dropbox.com/u/1735137/MapServer_firefox_chromium.png> in the
> browser with:
> http://localhost/cgi-bin/mapserv?map=/var/www/teste.map&mode=map
> The computer is running Ubuntu 10.04 with UbuntuGIS-unstable repository.
> The map file is located under the Apache folder (/var/www/teste.map) and
> trying to load a PostGIS layer.
> This is the content of my map file:
> MAP
> NAME "World map"
> SIZE 500 500
> UNITS meters
> IMAGECOLOR 28 28 55
> IMAGETYPE png
> PROJECTION
> "proj=latlong"
> "ellps=WGS84"
> END
> OUTPUTFORMAT
> NAME png
> DRIVER 'GD/PNG'
> IMAGEMODE RGBA
> EXTENSION 'png'
> END
> LAYER
> DATA "geom FROM 'sch_sig'.'wd_paises' USING UNIQUE gid USING srid=4326"
> NAME "wd_paises"
> TYPE POLYGON
> END
> END
> END
> Any clue of what I'm doing wrong?
> Thanks,
> Eloi Ribeiro
> GIS Analyst
> 39,45º -0,40º
> flavors.me/eloiribeiro<http://flavors.me/eloiribeiro>
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120626/57e5999a/attachment-0001.html>
