[mapserver-users] mapcache - is it possible to access different wms sources based on the current resolution or scale?
Mark Volz
MarkVolz at co.lyon.mn.us
Wed Jun 27 06:37:20 PDT 2012
Andreas,
The two layers are in the same grid. I didn't see any documentation on using symlink for zoom levels. How would I set that up in my configuration file?
Thanks
Mark Volz
GIS Specialist
-----Original Message-----
From: Eichner, Andreas - SID-NLKM [mailto:Andreas.Eichner at sid.sachsen.de]
Sent: Wednesday, June 27, 2012 5:10 AM
To: Mark Volz; MapserverList OSGEO
Subject: AW: [mapserver-users] mapcache - is it possible to access different wms sources based on the current resolution or scale?
If the grid matches, you can easily symlink the zoom levels.
HTH
> -----Ursprüngliche Nachricht-----
> Von: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Im Auftrag von Mark
> Volz
> Gesendet: Dienstag, 26. Juni 2012 23:28
> An: MapserverList OSGEO
> Betreff: [mapserver-users] mapcache - is it possible to access
> Hello,
> I would like to use mapcache to cache two layers. The first is a
> basemap that displays a political map when zoomed far out, or an air
> photo depending when zoomed in. The second layer displays that same
> air photo, but at all zoom levels.
> Is there any way to conserve disk space so the two layers share the
> same physical cache when zoomed in?
> Thanks
> Mark Volz
> GIS Specialist
