[mapserver-users] Curved Lines
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Wed Jun 27 07:47:43 PDT 2012
The question, if I understand is correctly, is relevant. In EPSG:4326 shortest distance between two points is better expressed as a curve than as a straight linestring. However, Mapserver does not support curves of any kind.
You may find some workaround from GDAL. Ogr2ogr is having a "segmentize" option for this purpose. It does not support real curves either, but it creates intermediate points so that linestrings are shorter and thus follow the curve better. See http://gdal.org/ogr2ogr.html
-Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Mr.
> Puneet Kishor
> Lähetetty: 27. kesäkuuta 2012 17:39
> Vastaanottaja: juliap
> Kopio: mapserver-users at lists.osgeo.org
> Aihe: Re: [mapserver-users] Curved Lines
> On Jun 27, 2012, at 2:13 AM, juliap wrote:
> > Hi all,
> > I have the following layer of type line :
> > LAYER
> > NAME line
> > STATUS ON
> > TYPE LINE
> > CONNECTIONTYPE OGR
> > CONNECTION
> "MSSQL:server=server;database=database;uid=id;pwd=pwd"
> > DATA "SELECT geometry::STLineFromText('LINESTRING ('
> > +CAST(Geo.STX AS VARCHAR(54))
> > +CAST(Geo.STY AS VARCHAR(54))
> > ,4326)
> > FROM column WHERE DATEDIFF(mi, CreatedON,
> CURRENT_TIMESTAMP) <='%x%'"
> > CLASS
> > STYLE
> > WIDTH 3
> > SIZE 1
> > COLOR 0 0 128
> > END # end of style
> > END # end of class
> > PROJECTION
> > "init=epsg:4326"
> > END # end of projection
> > END # end of layer
> > I was wondering how to get a curved line from this data. I
> tried using angle
> > and gap, but I don't see any changes.
> > Any suggestions?
> Your understanding of geometry is a bit off here. In a query
> result set, each row is a feature, and a line feature would
> be made up of two or points; a curved line feature, of
> course, would be made up of three or more points.
> What you are getting in the result set above is a bunch of
> features, each of which are a point repeated twice. I think
> what you really want is to create a single line feature from
> all these points. So, you would probably do some kind of an
> aggregate on these points. I don't know the functions
> available in SQL Server, but there must be an analog for
> Postgres's aggregate functions. You want to collect all the
> points and make a line feature from them, and then pass that
> to MapServer to draw. You could make a view that does all
> this, and then call the view from MapServer.
> Hope this helps.
> Puneet Kishor
