[mapserver-users] Fwd: facing problem in displaying map using
mapserver
Stephen Woodbridge
woodbri at swoodbridge.com
Thu May 3 08:38:40 EDT 2012
First, it is best to sent request to the list. If you are not signed up
signup here: mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
Second, the reason for 1 is that I have not used php mapscript in ages
and I don't use windows very much and I have never used fusion. So on
the list there is a better chance that you will find someone from the
many users that can help you.
Also there are lists specifically for MS4W and I'm guessing also for
fusion which might be better than the general mapserver list. You can
test you mapfile directly in mapserver with shp2img utility to validate
your mapfile. If this doesn't throw an error then it is likely that you
have errors in your fusion configuration and need to talk to the fusion
list for help with that.
-Steve
-------- Original Message --------
Subject: facing problem in displaying map using mapserver
Date: Thu, 03 May 2012 02:21:36 -0700
To: woodbri at swoodbridge.com
Hi Stephen,
I have recently started working on GIS stuff, i have created mapfiles
and for
displaying them i am using fusion as an interface. I have modified
ApplicationData.xml and updated <MapFile> tag with path where my mapfile is
saved on my computer, but the problem is its not displaying any map, i
checked error file and it contains following:
[Mon Apr 09 12:30:15 2012] [error] [client 127.0.0.1] thrown in
C:\\ms4w\\apps\\fusion\\MapServer\\php\\LoadMap.php on line 129, referer:
http://localhost/fusion/templates/mapserver/standard/index.html
[Mon Apr 09 12:30:16 2012] [error] [client 127.0.0.1] PHP Fatal error:
Uncaught exception 'MapScriptException' with message 'Property 'imagetype'
does not exist in this object.' in
C:\\ms4w\\apps\\fusion\\MapServer\\php\\LoadMap.php:129, referer:
[Mon Apr 09 12:30:16 2012] [error] [client 127.0.0.1] Stack trace:, referer:
[Mon Apr 09 12:30:16 2012] [error] [client 127.0.0.1] #0
C:\\ms4w\\apps\\fusion\\MapServer\\php\\LoadMap.php(129):
mapObj->__get('imagetype'), referer:
[Mon Apr 09 12:30:16 2012] [error] [client 127.0.0.1] #1 {main}, referer:
[Mon Apr 09 12:30:16 2012] [error] [client 127.0.0.1] thrown in
I have been stuck with this problem for a week now, i am feeling totally
clueless about how to proceed, any help from your side will be apreciated.
Thanks and Regards
Badrul
