[mapserver-users] Mapserver layer over Google Maps
Dejan Gambin
dejan.gambin at coin.hr
Mon May 7 02:19:50 EDT 2012
Alberto,
I found this VERY useful: http://geographika.co.uk/mapserver-openlayers-and-the-wfs-maze
I think you should put EPSG:3857 on the first place in wms_srs
regards, dejan
On 7. svi. 2012., at 03:33, Alberto Najera wrote:
> Hello list,
> Using OpenLayers, I am trying to draw a Mapserver WMS layer on top of Google
> Maps. I am aware of the Spherical Mercator projection and I am trying to use
> the alias projection method described at the end of this link
> http://docs.openlayers.org/library/spherical_mercator
> The mapserver layer is in Lat/Lon WGS84 (EPSG:4326)
> I have made some progress so far and I can see the label of the object at
> full zoom, but as I zoom in it does not show anymore and the feature does
> not show either.
> Any help in finding the issue would be greatly appreciated.
> This is the relevant map file code:
> MAP
> WEB
> TEMPLATE "/home/bicimapas/www/bcmpms.html"
> IMAGEPATH "/home/bicimapas/www/images/"
> IMAGEURL "/images/"
> METADATA
> "wms_title" "BiciMapasMS"
> "wms_onlineresource"
> "http://my_host/cgi-bin/mapserv?map=/home/bicimapas/mapdata/BiciMapasMS_Metr
> o.map&"
> "wms_srs" "EPSG:4326 EPSG:3857"
> "wms_enable_request" "*"
> END
> END
> PROJECTION
> "init=epsg:4326"
> END
> LAYER
> NAME "fibraoptica"
> DATA "fibraoptica"
> STATUS on
> TYPE line
> LABELCACHE on
> LABELITEM "RASGO"
> CLASSITEM "RASGO"
> METADATA
> "wms_title" "fibraoptica"
> "wms_srs" "EPSG:4326"
> "wms_include_items" "all"
> END
> CLASS
> NAME "fibraoptica"
> EXPRESSION "fibra"
> #MAXSCALEDENOM 15000
> STYLE
> WIDTH 4
> COLOR 0 0 0
> END
> STYLE
> WIDTH 2
> COLOR 255 0 0
> END
> LABEL
> TYPE truetype
> FONT "Arial"
> ANTIALIAS true
> SIZE 7
> OUTLINECOLOR 255 255 255
> COLOR 0 0 0
> POSITION cc
> ANGLE follow
> END # label trutype
> END # class fibraoptica
> END # layer fibraoptica
> END # mapfile
> And the OpenLayers code is:
> <html lang='en'>
> <head>
> <meta charset='utf-8' />
> <script type='text/javascript' src='OpenLayers.js'></script>
> <script
> src="http://maps.google.com/maps/api/js?sensor=false"></script>
> <script type='text/javascript'>
> var map;
> function init() {
> // Setup map object
> map = new OpenLayers.Map('map_element', {});
> // Add Google Maps Layer
> var google_map_layer = new OpenLayers.Layer.Google(
> 'Google Map Layer',
> {"sphericalMercator": true}
> // override default epsg code
> aliasproj = new OpenLayers.Projection("EPSG:3857");
> google_map_layer.projection = aliasproj;
> // Add the Google Maps layer
> map.addLayer(google_map_layer);
> //add the mapserver layer
> var layer3 = new OpenLayers.Layer.WMS(
> "Fibra Optica",
> "http://my_host/cgi-bin/mapserv?",
> {map: '/home/bicimapas/mapdata/BiciMapasMS_Metro.map',
> layers:'fibraoptica', transparent: true},
> {isBaseLayer:false});
> // Add the layer
> map.addLayer(layer3);
> // Add a layer switcher control
> map.addControl(new OpenLayers.Control.LayerSwitcher({}));
> //Zoom the map to the max extent
> if(!map.getCenter()){
> map.zoomToMaxExtent();
> </script>
> </head>
> Thanks in advance
> Alberto Najera
> mapserver-users at lists.osgeo.org
