[mapserver-users] polygon border artifacts
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Mon May 7 14:04:58 EDT 2012
Perhaps it is mostly an AGG issue because I think that Mapnik makes similar artifacts too. See Corine landuse polygons here http://www.openstreetmap.org/?lat=60.820709&lon=27.201925&zoom=18&layers=M
Sea areas do not have artifacts in OSM because sea is just background colour and is is not rendered at all from any data. But I do not know what Mapnik is doing with the land polygons. I cannot see artifacts between them in OMS maps.
-Jukka Rahkonen-
Lime, Steve D wrote:
> I tried locally and it's definitely a rendering artifact related to anti-aliasing. Should an outline always be drawn?
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf > Of Sven Geggus
> Sent: Friday, May 04, 2012 6:04 AM
> To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] polygon border artifacts
thomas bonfort <thomas.bonfort at gmail.com> wrote:
> with a recentish version of mapserver, try setting PROCESSING
> "APPROXIMATION_SCALE=FULL"
> on your ocean layer, to avoid feature simplification (it will slow
> down the rendering if the resolution of your data is much greater than
> the resolution of the requested map).
Hm. Looking at the sources 6.0.1 seems to be recent enough, but unfortunately this does not seem to fix the problem.
Regards
Sven
Den Rechtsstaat macht aus, dass Unschuldige wieder frei kommen (Wolfgang Schäuble)
/me is giggls at ircnet, http://sven.gegg.us/ on the Web _______________________________________________
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
