[mapserver-users] multiple transparent colours
Christoph Schumacher
christoph.schumacher at pbs-schumacher.de
Thu May 10 02:45:31 EDT 2012
hi everybody,
first i have to say thank you for all the answers.
I tried the RGBA way by defining a RGBA Palett file with quadrupels (e.g. 0,0,0,0) for the RGBA values of my transparent colours.
It´s the first time for me using RGBA so maybe I´m on the wrong way, but how do i define the transparency in the Layer section???
best wishes and thank you
christoph
> Hi,
> Just came into my mind that I have had problems with OFFSITE and tileindex. It
> makes the desired pixel value transparent with WMS but not with WCS. At least is
> was so in the past. I have not produced WCS lately. The workaround was to make a VRT
> file from with gdalbuildvrt and use that as input for the WCS mapfile. That way
> nodata worked as it should and we got proper images out of WCS even with warped
> source images. I am not sure if I ever made a ticket from that. Perhaps not or then
> just nobody ever reacted.
> So I suppose that "OFFSITE AUTO" happens already if you use VRT as input instead of
> tileindex. I have not seen big difference in speed between tileindex and VRT.
> However, I use normally tileindex system because I can open and manage the index
> files with GIS programs.
> -Jukka Rahkonen-
> Stephen Woodbridge wrote:
>> Lähetetty: 9. toukokuuta 2012 16:45
>> Vastaanottaja: mapserver-users at lists.osgeo.org
>> Aihe: Re: [mapserver-users] multiple transparent colours
>> Frank,
>> Would it be possible to make mapserver pick up the NODATA
>> value from the
>> gdal source file. Maybe using a keyword like "OFFSITE AUTO".
>> This would
>> be especially useful when using a tileindex.
>> Any thoughts on this? Should I create a ticket for something
>> like this?
>> -Steve W
>> On 5/9/2012 9:36 AM, Rahkonen Jukka wrote:
>> > Hi,
>> > Perhaps you cannot literally set a colour as transparent in
>> a tiff but
>> > for sure you can define a nodata value and then
>> applications can make
>> > nodata pixels transparent. That is the most normal way to do it with
>> > Mapserver and OFFSITE. I believe that Mapserver does not
>> even care if
>> > tiff has a nodata tag set but you can give whatever value
>> for offsite in
>> > a mapfile.
>> > I have not played at all with alpha, but perhaps there is
>> some way to
>> > give a list of pixel values which should be transparent and
>> convert them
>> > all to a suitable alpha channel value.
>> > -Jukka Rahkonen-
>> > Fernando Nortewrote:
>> > Hi Christoph,
>> > I try to understand, how did you set the specific color to
>> > transparent in a TIFF?
>> > For raster you can set the level of transparency/opacity to the
>> > image not to a color.
>> > Att,
>> > *Fernando Norte*
>> > Desenvolvedor SIGWeb
>> > tel.(31) 2533.9900
>> > cel.(31) 9119.8814
>> > skype: fernandoglobalgeo
>> > Endereço: Alameda do Ingá, 88, 6º andar, Vale do Sereno
>> > Nova Lima/MG - CEP: 34.000-000
>> > www.globalgeo.com.br <http://www.globalgeo.com.br/>
>> > "O presente documento pode conter material confidencial ou seu
>> > sigilo é protegido por lei.
>> > Quaisquer informações nele contida são destinadas exclusivamente
>> > ao(s) seu(s) destinatário(s)
>> > não devendo em nenhuma hipótese ser repassado a terceiros".
>> > 2012/5/9 Christoph Schumacher
>> > mailto:christoph.schumacher at pbs-schumacher.de
>> > Hello everybody,
>> > I have a problem setting up my wms.
>> > I have multiple tiff images that have different
>> colours to be
>> > set up as transparaent.
>> > With the offsite parameter I can only set one
>> colour transparent.
>> > Now my question is: Is there a way to make various colour
>> > transparent??
>> > best wishes and thank you very much
>> > christoph
>> > _______________________________________________
>> > mapserver-users mailing list
>> > mailto:mapserver-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
Freundliche Grüße
planungsbüro schumacher
Im Auftrag
gez. Christoph Schumacher
Telefon 02262 7205-13
__________________________________________________________________
pbs planungsbüro schumacher
Dipl.-Ing. Jürgen Schumacher
Oststraße 8, 51674 Wiehl
Telefon 02262 7205-0, Fax 02262 7205-6
info at pbs-schumacher.de
http://www.pbs-schumacher.de
Wir garantieren nicht für Fehler- bzw. Virenfreiheit der E-Mail und/oder
angehängten Dateien. Für Schäden, die aus der Nutzung der Daten
entstehen, übernehmen wir keine Haftung. Bitte prüfen Sie die Daten
vor der Nutzung.
