[mapserver-users] Help Required with WMS Time
Helen San Segundo Navazo
hsansegundo at meteo.cat
Fri May 11 03:11:47 EDT 2012
* for the first point, in my last email you have an example with a
raster file, here you have it, in it the variable is the full file
name, but you can do it how is better for you, being careful with
the pattern
LAYER
NAME 'Meteosat'
TYPE RASTER
DUMP true
TOLERANCE 10
TOLERANCEUNITS DD
HEADER "templates/getfeatureinfo_header.html" # header html template
TEMPLATE "templates/getfeatureinfo_content.html" # content html
template
FOOTER "templates/getfeatureinfo_footer.html" # footer html template
METADATA
'ows_title' 'Meteosat'
'wms_feature_info_mime_type' "text/html"
"gml_include_items" "all"
"wms_include_items" "all"
"ows_enable_request" "*"
'file_validation_pattern' "[A-Z0-9._%+-|'\(\)]"
'default_file' "ultima_imatge"
END
VALIDATION
'file' "[A-Z0-9._%+-|'\(\)]"
END
DATA '/var/www/html/mapserver/mfd_lin/datos/meteosat/%file%.img'
* For the second point, till I know, the function shp2pgsql creates a
script with all the attributes you have in the shapefile, if you
want to have a time column that is not in the shapefile, you have to
add it later after creating the table in the database, maybe
somebody in the list knows how to do it automatically when you
invoke shp2pgsql.
Helen
El 11/05/12 06:47, abhishek bansal escribió:
> Hi Helen,
> I think I will have to do it ultimately by your way. Sorry for
> bothering you but could you please help me with these two questions
> 1.) Will i be able to get raster data also with this method ?
> 2.) How do I include time data in postgis database as it is created
> automatically by shp2pgsql utility ?
> Thank You
> Abhishek Bansal
> On Thu, May 10, 2012 at 6:59 PM, Helen San Segundo Navazo
> <hsansegundo at meteo.cat <mailto:hsansegundo at meteo.cat>> wrote:
> ok, good luck
> El 10/05/12 14:26, abhishek bansal escribió:
>> But I dont want to use any database either !!
>> On Thu, May 10, 2012 at 5:47 PM, Helen San Segundo Navazo
>> using the runtime substitution you can use getcapabilities
>> request with all the description to see layers, proyections
>> ...., it works as if you don't use the variables
>> Here you have an example using a binary file
>> LAYER
>> NAME 'Meteosat'
>> TYPE RASTER
>> DUMP true
>> TOLERANCE 10
>> TOLERANCEUNITS DD
>> html template
>> content html template
>> html template
>> METADATA
>> END
>> VALIDATION
>> END
>> DATA
>> El 10/05/12 14:08, abhishek bansal escribió:
>>> Hi,
>>> Thanks for your reply.
>>> But I need to specify in map file which layers are available
>>> so that i can parse output of getCapabilities and show
>>> available layers to user.
>>> Also I am not using any database.
>>> On Thu, May 10, 2012 at 5:18 PM, Helen San Segundo Navazo
>>> Hi,
>>> I don't use the time dimension, what I use is run-time
>>> substitution http://mapserver.org/cgi/runsub.html
>>> I have 6 variables. You have to put the validation
>>> pattern inside the metadata tag and a validation tag
>>> with the pattern of your variables.
>>> With this you can invoke the params in the url. If you
>>> put them the query will be with the values in the url,
>>> if not, then the query will be with the default values
>>> defined in the metadata tag.
>>> Hope this help you,
>>> Helen
>>> LAYER
>>> NAME 'name'
>>> METADATA
>>> 'ows_title' 'title'
>>> 'aini_validation_pattern' '^[0-9]{1,8}$'
>>> 'afi_validation_pattern' '^[0-9]{1,8}$'
>>> 'mini_validation_pattern' '^[0-9]{1,8}$'
>>> 'mfi_validation_pattern' '^[0-9]{1,8}$'
>>> 'dini_validation_pattern' '^[0-9]{1,8}$'
>>> 'dfi_validation_pattern' '^[0-9]{1,8}$'
>>> 'default_aini' '2012'
>>> 'default_afi' '2012'
>>> 'default_mini' '4'
>>> 'default_mfi' '4'
>>> 'default_dini' '24'
>>> 'default_dfi' '25'
>>> END
>>> VALIDATION
>>> 'aini' '^[0-9]{1,8}$'
>>> 'afi' '^[0-9]{1,8}$'
>>> 'mini' '^[0-9]{1,8}$'
>>> 'mfi' '^[0-9]{1,8}$'
>>> 'dini' '^[0-9]{1,8}$'
>>> 'dfi' '^[0-9]{1,8}$'
>>> END
>>> STATUS OFF
>>> PROJECTION
>>> "init=epsg:4326"
>>> END
>>> CONNECTIONTYPE postgis
>>> CONNECTION "user=postgres password=pp dbname=mm
>>> host=host"
>>> DATA "the_geom FROM (SELECT oid,geometry_columns
>>> from table
>>> where
>>> time>='%aini%-%mini%-%dini% 00:00:00'
>>> and
>>> time<'%afi%-%mfi%-%dfi% 00:00:00'
>>> AS r USING UNIQUE oid USING SRID=4326"
>>> El 10/05/12 13:24, abhishek bansal escribió:
>>>> Hello All
>>>> I am working on a project that require time as a
>>>> dimension of data. I have gone through all
>>>> documentation but I am not able to understand that how
>>>> do I upload time data in server .map file. I have
>>>> created simple map files and my server is working. What
>>>> i need is same layer on different time should different
>>>> dataset.
>>>> plz help !!
>>>> Thanks & Regards,
>>>> Abhishek Bansal
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>>> Thanks & Regards,
>>> Abhishek Bansal
>>> http://abhishekbansal.miyuri.com
>>> Jaypee Institute of Information Technology, Noida
>> Thanks & Regards,
>> Abhishek Bansal
> Thanks & Regards,
> Abhishek Bansal
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120511/10aa3e64/attachment-0001.html
