[mapserver-users] Re: Scale changes to mapserver 6.1-dev
Peter Maes
thxftw at gmail.com
Fri May 11 09:07:30 EDT 2012
When I run the mapfile with shp2img i get proper results.
So in all likelyhood it will have to do with mode gmaps. I'll give a try
with wms in the mean while.
It seems as if for some reason i get the entire map rendered, for every
tile requested.
2012/5/11 Peter Maes <thxftw at gmail.com>
> Hi,
> Did something change in regards to the scales? I took an existing mapfile
> config (that worked fine on mapserver 6.0) and ran that now with 6.1-DEV.
> However i get repeated messages stating:
> msLayerIsVisible(): Skipping layer (L1) because LAYER.MAXSCALE is too
> small for this MAP scale
> When I remove the layer, the layer gets drawn, however it does not match
> the scale of google maps.
> In fact, at a zoomed in level, i see my layer draw 6 times next to
> eachother (as you would have on google zoom 0-2).
> Best regards.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120511/45d91079/attachment.html
