[mapserver-users] Re: polygon border artifacts
Sven Geggus
lists at fuchsschwanzdomain.de
Sun May 13 10:13:41 EDT 2012
Sven Geggus <lists at fuchsschwanzdomain.de> wrote:
> OK YFTR:
> Rendering water from Overlapping polygons does work fine in mapserver
> 6.0.x using the "APPROXIMATION_SCALE=FULL" PROCESSING directive.
> "FORMATOPTION GAMMA=0.7" does not seem to be needed but won't be
> available in version 6.0.x anyway.
> My problem was mith the specification of multiple PROCESSING
> directives.
> The following syntax does not work, but does not result in a mapfile
> parser error either:
> PROCESSING "DIRECTIVE1=value1 DIRECTIVE2=value2"
> Instead the following must be used:
> PROCESSING "DIRECTIVE1=value1"
> PROCESSING "DIRECTIVE2=value2"
> In my case these are:
> PROCESSING "CLOSE_CONNECTION=DEFER"
> PROCESSING "APPROXIMATION_SCALE=FULL"
Oh well, here comes another FTR posting as this is only true with
OUTLINECOLOR and "WIDTH 0" specified which does produce other strange
artifacts in small zoomlevels.
When OUTLINECOLOR and WIDTH are omitted the border artifacts are back.
So here is the solution which is producing the desired results:
* Use mapserver from git master (6.1-dev)
* Render ocean polygons using a mapfile like the following:
--cut--
MAP
OUTPUTFORMAT
NAME agg
DRIVER AGG/PNG8
FORMATOPTION "INTERLACE=OFF"
FORMATOPTION "GAMMA=0.6"
MIMETYPE "image/png"
END
WEB
METADATA
"ows_enable_request" "*"
wms_srs "EPSG:4326 EPSG:3857"
END
END
PROJECTION
"init=epsg:3857"
END
LAYER
DEBUG 9
NAME "ocean"
TYPE POLYGON
STATUS ON
DATA "ocean-120328"
PROJECTION
"init=epsg:3857"
END
CLASS
STYLE
COLOR "#579ae3"
END
END # of class
END # of layer
END
--cut--
Sven
"The only thing we have to fear is fear itself" (Franklin D. Roosevelt)
/me is giggls at ircnet, http://sven.gegg.us/ on the Web
