[mapserver-users] text size from field but with an expression
thomas bonfort
thomas.bonfort at gmail.com
Thu Oct 4 01:49:39 PDT 2012
On Thu, Oct 4, 2012 at 10:04 AM, Andrea Peri <aperi2007 at gmail.com> wrote:
> Hi,
> I have a label with the size from a field of attributes.
> But I need to change this size adding always a costant factor.
> I need someting like:
> LABEL
> SIZE expression([field1]+10)
> ANGLE [field2]
> END
> This seem don't allowed.
> Is this right ?
correct. if you are using a db backend, you can let the db do this for you:
DATA "the_geom from (select id,the_geom,field1+10 as field1, field2
from mytable) as foo using unique id using srid=xxx"
> Thx,
> Andrea Peri
> qwerty àèìòù
> mapserver-users at lists.osgeo.org
