[mapserver-users] text size from field but with an expression
Andrea Peri
aperi2007 at gmail.com
Thu Oct 4 02:08:12 PDT 2012
ok, thx.
Infact I'm using spatialite db.
So I hope to have success to support this sintax.
Now I'm try.
Thx.
2012/10/4 thomas bonfort <thomas.bonfort at gmail.com>
> On Thu, Oct 4, 2012 at 10:04 AM, Andrea Peri <aperi2007 at gmail.com> wrote:
> > Hi,
> > I have a label with the size from a field of attributes.
> > But I need to change this size adding always a costant factor.
> > I need someting like:
> > LABEL
> > SIZE expression([field1]+10)
> > ANGLE [field2]
> > END
> > This seem don't allowed.
> > Is this right ?
> correct. if you are using a db backend, you can let the db do this for you:
> DATA "the_geom from (select id,the_geom,field1+10 as field1, field2
> from mytable) as foo using unique id using srid=xxx"
> > Thx,
> > Andrea Peri
> > qwerty àèìòù
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20121004/52677647/attachment.html>
