[mapserver-users] WFS fails if table name includes a dot character
Puneet Kishor
punk.kish at gmail.com
Tue Oct 9 08:14:16 PDT 2012
On Oct 9, 2012, at 7:51 AM, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi> wrote:
> Hi,
> It may be an odd idea to use dots in table/feature type names, but because I made such a test and faced a problem so I report it here.
> Source table is in PostGIS and its name is "dot.test". WFS DescribeFeatureType leads to following error
> [Tue Oct 9 10:56:02 2012].214191 msPostGISLayerGetItems(): Query error. Error
> (ERROR: schema "dot" does not exist
> LINE 1: select * from dot.test where false limit 0
> ) executing SQL: select * from dot.test where false limit 0
> [Tue Oct 9 10:57:12 2012].923891 msPostGISLayerGetItems(): Query error. Error
> -Jukka Rahkonen-
> mapserver-users at lists.osgeo.org
If using non-standard characters, double quote the entity name. So, try
SELECT * FROM "dot.test" WHERE ...
To be completely unambiguous, prefix the schema name. So, if the table is in schema foo, try
SELECT * FROM "foo.dot.test" WHERE ...
Puneet Kishor
